I see the 499 reference. What exactly are you looking to do? Why make a change? Is the combo not doing something it should, or are you just addicted and want to go faster
?(my personal favorite is that last one)
What heads do you run now? DO you have any flow specs form the heads when it was built? Most aftermarket heads will take well past .700 valve lift before retainers hit. Piston to valve clearance needs the pockets in teh pistons, but duration and lobe design make a huge difference too. I'd venture to say you could make a change easy to .650+, but really you need to measure it. If the duration of your cam is such that the valves are close to the pistons, adding extra lift may be fatal. That's why we "clay the piston" to verify piston to valve clearance witht he cam in the spot it will be run in.
