Author Topic: Rebuilding the trani  (Read 44401 times)
Offline tactransman
Re: Rebuilding the trani
« Reply #150 on: December 30, 2006 - 08:14:28 PM »
Bob, did you look at the book I sent you?  Does it help you better ? I suggest you look all the way thru it a couple of times before reassembly. :grinyes:
Terry-tactransman
Union, Mo.
Offline RDF
  • The pain that greets me is the stick that beats me
« Reply #151 on: December 30, 2006 - 08:20:18 PM »
Yeah, I checked out the book and it is helping me a bit more than the other book.  It's illustrations are good, but for this pic, it's hard to make out where the spring is supposed to go and where the roller is supposed to go.  I did a google search and found an image that was better, so that's where I knew how to place them, but I'm still having a little trouble getting all of them to be compressed evenly.  Is there a secret to this?  :clueless:  :dunno:
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
Offline tactransman
« Reply #152 on: December 30, 2006 - 08:25:00 PM »
They do not have to be perfect, when you put the drum in, you will turn it as you push it in and it will center on it's own. It only has to be close.
Terry-tactransman
Union, Mo.
Offline RDF
« Reply #153 on: December 30, 2006 - 08:35:38 PM »
Ok, cause I've got 8 of them close, and 2 are ok, but if I spin the gear, then they all seem to move anyhow, so I was wondering about that.  I'm done for the night, I'll take your advice and re-read the book tonight so I know what I'm getting into tomorrow.
Thanks T!  :jumping:
Bob
1973 'Cuda
My build:
Offline tactransman
« Reply #154 on: December 30, 2006 - 08:41:51 PM »
 :2thumbs:
Terry-tactransman
Union, Mo.
Offline RDF
« Reply #155 on: December 30, 2006 - 08:44:47 PM »
Opps...forgot to post the pic....here it is.....there's also the image from the book that I was talking about.  Kinda hard to make out....
Bob
1973 'Cuda
My build:
Offline tactransman
« Reply #156 on: December 30, 2006 - 09:02:04 PM »
Looks good to me! :bananasmi
Terry-tactransman
Union, Mo.
« Reply #157 on: December 30, 2006 - 10:28:39 PM »
notice in the pic some "springs" are oriented differently. it that OK?
Offline tactransman
« Reply #158 on: December 31, 2006 - 03:29:13 AM »
:grinyes:
Terry-tactransman
Union, Mo.
Offline RDF
« Reply #159 on: December 31, 2006 - 06:19:31 AM »
Ok, it's Sunday and no time to rest.  My plan is to have this trani back together today so I can start putting my car back together tonight  :working: and have it running by late tomorrow.  :burnout:  Wish me luck, with 2 kids under 3, I don't know if I'll be able to do it!  :banghead:
Bob
1973 'Cuda
My build:
Offline Plum6Pak
  • Plum6Pak
« Reply #160 on: December 31, 2006 - 07:30:12 AM »
Sounds like a good new years resolution to me, good luck!  :2thumbs:
Offline RDF
« Reply #161 on: December 31, 2006 - 09:09:31 AM »
TTM,
Should I replace the seal on the low reverse servo?  I'm worried about compressing the spring and getting hurt.  :bricks1:
Bob
1973 'Cuda
My build:
Offline tactransman
« Reply #162 on: December 31, 2006 - 09:32:39 AM »
Yes, you have to change all rubber seals. You need to look at your shift kit also, there should be a shim in it for the rear servo piston. THE SHIM IS A MUST! The spring tension shouldn't be too much for you.
Terry-tactransman
Union, Mo.
Offline RDF
« Reply #163 on: December 31, 2006 - 10:19:56 AM »
I didn't see a shim in the kit, but looking at the directions, it says to use the short spring in place of the original one.  So I used that and installed the rear servo.  I'm trying to get the guts (rear drum, drum, gears, etc.) back into the case and bolt the pump on.  I've got a c-clamp that I'm not too sure where it goes, but I'm gonna have a look at my parts manual and see if I can find it.
Bob
1973 'Cuda
My build:
Offline tactransman
« Reply #164 on: December 31, 2006 - 10:32:54 AM »
Rear servo HAS to shimmed or you cannot make a manual 1-2 shift without a horrible bind up.
See pic from the Archives:
Terry-tactransman
Union, Mo.
