RDF,
I don't know if you're using a manual or not, but don't forget to change the inner and outer piston seals in your drums. The blindfolded guy doing the trans on Goody's Dads' car on Overhauling, didn't bother doing them and just changed the clutches and steels. If you don't change those seals, you can end up not having a couple of gears such as Reverse or 3rd after putiing it back in. Then it would all have to come apart again.
I learned that the hard way the very first time I did a tranny back in '83. I welded up my own threaded clamp to compress the hi gear drum to compress the springs to pull out the retaining ring. Look at your drums with all of the clutches out of it. The lower remaining piece is the piston, that has the two seals still on it. The one with the springs still on it is the one that will be a real puta to get off. Once you get the seals changed, use lots of tranny fluid to lube it up and work the seal lips with a thin feeler guage to get it back it. Work slowly or you will cut the lips.
Getting the big piston out and back in is the hardest part of rebuilding a trans. Also, the front pump bolts snap off very easily so just snug them up if you don't use a torque wrench. If you snap one, pull the pump back off to unthread it with a pair of pliers.
Good luck with it.
