Ok, another day and more parts are out!
After talking with TTM, I put the trani back together and took it down to the local car war and used oven cleaner on it (as recommended) and sprayed it down with the hose. All was good except the camera's watching me and the big huge sign that said no dumping of chemicals or other polutants down the drains. Oh well, I guess the cops will be at my house soon.
Got it back home, disassembled to where I was last night and started again. Removed the snap ring from the rear shaft and then removed the bearing. Took out the small e-clip on the governor and then pushed the governor out. I then removed the other snap-ring holding the governor housing in place and took off the housing. All went well. I'm stuck on the removing the pump now. I bought a slide hammer about 2 weeks ago and didn't realize it was a heavy duty one, for trucks, so it's of no use to me. I tried to pry (as per instructions from TTM (See pic above))
but I had no luck.
Should I see the front (where the converter sits) move when I pry? I tried looking at it and it never moved. Seems like something is still holding it, but I could be wrong.
TTM, should I remove the band lever (??)
that is part of the band adjuster? It's hard for me to explain, but when I backed out the adjuster bolt, the band clamp lossened all the way and a small, 2" metal piece was able to come out.
At any rate, that's where my journey ends tonight. I'll be back at it tomorrow, prob. around the same times.
As you can see in the pics, the housing looks 100% cleaner, although I missed some small areas, 95% is cleaner.
