ok, trani is back together, couple of worry-some questions....
1.) Should I be able to turn the shaft from the rear?
![:clueless: :clueless:](http://www.cuda-challenger.com/cc/Smileys/default/clueless.gif)
I didn't put the extension housing on yet so the rear shaft is exposed and the front servo is not in. The front band is on, but not tight with the lever b/c the front servo isn't in. I didn't want to put it all together only to find out it's all got to come out.
![Faint :faint:](http://www.cuda-challenger.com/cc/Smileys/default/faint.gif)
One thing I did try was removing all the bolts from the pump, but leaving the pump in and the gear turns.
2.) My endplay is 0. The shaft does not move at all, in or out.
![Dunno :dunno:](http://www.cuda-challenger.com/cc/Smileys/default/dunno.gif)
I've tightened the pump bolts and the drums and things seems to go together smoothly. I did put the small thrust washer between the output shafts and held it in place with a little bit of grease.
