K-Member
Author Topic: K-Member  (Read 867 times)
Offline TreeFrog
    • TreeFrog
K-Member
« on: December 05, 2006 - 11:20:24 AM »
if I change the small block out in a challenger for a big block, does the k-member have to change?
I believe a /6, and HEMI do for sure, and I recall some adjustments in the Tor-bars ... :working:
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline heminut
Re: K-Member
« Reply #1 on: December 05, 2006 - 12:06:11 PM »
No, the small block k member will work just fine with the big block. You may have to adjust the torsion bars up a little, but they will work also.
1970 5.7 Hemi Cuda
Re: K-Member
« Reply #2 on: December 05, 2006 - 02:42:18 PM »
You should really have thicker torsion bars for a big block though, but it isn't a must. You will need different motor mounts for the big block too.
Offline TreeFrog
    • TreeFrog
Re: K-Member
« Reply #3 on: December 06, 2006 - 06:42:27 AM »
I have never touched a Torsion Bar ... heard stories good and bad.  Where would I find a set of hevy duty ones?  Please don't say junk yard...my knees could not take the pressure in this area... :sly:
Offline moper
Re: K-Member
« Reply #4 on: December 06, 2006 - 07:59:47 AM »
Pick up a summit, jegs, or Mancini Racing/MP catalog. They are all in there.
Offline heminut
Re: K-Member
« Reply #5 on: December 06, 2006 - 09:57:52 AM »
There's really not that much difference in the torsion bars. I'm running the stock bars in my Cuda with the 392, which weighs about 200 lbs more than a smallblock, and the bigblock is only about 100 lbs heavier than a smallblock if even that much. An old drag racing trick was to run /6 bars under the hemi cars to get more lift on the launch, and they worked just fine!
1970 5.7 Hemi Cuda
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
Re: K-Member
« Reply #6 on: December 06, 2006 - 03:18:16 PM »
I have a 440 in my 69 and that was a 318 car from the begining and it work just fine :bigsmile:
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
