Author Topic: Cam selection for a 383  (Read 6956 times)
Re: Cam selection for a 383
« Reply #15 on: December 08, 2006 - 07:23:48 PM »
 :2thumbs:
 Let me know what you think when you get it running
 you are welcome BTW
Offline moparnut
    • My Photo's
« Reply #16 on: December 09, 2006 - 01:37:36 PM »
Another ?,CaN i run stock 10-1 pistons on my 383 build with 915 heads and still run pump gas?Would i just use a different head gasket and what would the Comp be?if so which one?Its just easier for me to find cheaper hyper stock 10-1 pistons.
Thanks :thumbsup:
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline loco440
« Reply #17 on: December 19, 2006 - 08:18:32 PM »
I have been watching this debate with intrest,Chryco perhaps you could clear some things up for me also, I have a power braked 4 speed 3.55 rear challenger with a fresh 440 bored 40 over with stock ex manifolds and I am fitting a new 6pack setup,I am also thinking of Engle K58 with a lobe centre of 112 for street use,do think this would be a good set up? thanks.
« Reply #18 on: December 21, 2006 - 01:13:39 AM »
looks like a good combo to me , I did a 440 +6 for a customer last year we used a Lunati solid cam , 112* CL & 1.6 ratio  rockers with if I remember right [ 238*@.050] & 586 lift { I can look it up tomorrow for sure , it idles like stock with a mild lope & simply Howls when you get on it , it made 315 RWHP on  a Mustang Dyno & correction to Gross hp is 1.6 so it has 520 gross HP which is 125 hp more then stock & still looks stock & uses the iron exhaust manifolds & stock 906 heads ported
« Reply #19 on: December 21, 2006 - 01:15:30 AM »
Thanks :thumbsup:
 Remind me fri & I will work out the math on your combo , with a true 9.8:1 compression & quench & some tweaking of the timing curve you should have no problem running this combo on pump gas
Offline moparnut
    • My Photo's
« Reply #20 on: December 22, 2006 - 08:48:27 AM »
Thanks Chryco,I was actually referring to 10-1 pistons with 906's but using 915's so it would be around 10.8(ish)-1.Is there a head gasket that would bring it back closer to 10-1?My best choice is stock pistons from a 383-2 at 9.2-1 that would get me real close to 10-1 with 915's.I still have yet to find someone making the 383-2 pistons still,maybe i'll keep my eye out for some on EGAG.I sill may just bite the bullet and go with your recommended TRW L2315's fordged
« Reply #21 on: December 22, 2006 - 12:21:02 PM »
a 10:1 piston @ 10.8 with closed chamber heads is too high for pump gas , using a thick head gasket to raise the head will lose the quench effect so that is not a good I dea , the best is to use the 9.8 compression piston with the closed chamber head , use a .035 thick head gasket & zero deck the block so the piston is .005 below deck  , this will max the compression for pump fuel & give you the quench to kill detonation
Offline moparnut
    • My Photo's
« Reply #22 on: December 22, 2006 - 09:51:43 PM »
thanks
Offline mrbill426
    • All Around Mopars
« Reply #23 on: April 28, 2007 - 10:00:19 AM »
Just got off the phone with Chris at Engle Cams, I ordered the 'K58' to be custom ground at 112* on Chryco's suggestion.  Chris agreed that the 112* CL will be a good choice; adding more vacuum for my power accessories while smoothing the idle slightly, improving drivability.  Perfect for my set-up, thanks Chryco!
 :feedback: How did it work out?
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #24 on: April 28, 2007 - 12:02:41 PM »
I'll let you all know how it works out, but not 'till next year when the resto is completed.  Thanks everyone!
Offline Hot_Rodder
« Reply #25 on: April 28, 2007 - 03:32:23 PM »
for example the Mopar .509 cam really has a choppy idle
 :woohoo: Yeah but man oh man, it's sounds nice, :bigsmile: I liked it, and hammer the throttle, and hang on, lol. :cooldancing:
