Engine Oil
Author Topic: Engine Oil  (Read 2181 times)
Offline vinb
Engine Oil
« on: December 05, 2006 - 03:38:16 PM »
Just a quick note to anyone buying any engine oil. I noticed that the Shell/Rotella-T 15W-40w no longer has CI-4 Plus rating. It said something about (triple protection) I was just wondering if they changed the formula and if it has less additives for our older engines. The new label has a yellow/gold swirl and the old ones are solid blue. Chryco-Psycho
maybe you can find out what's the scoop is on this..........Thanks Vin.............
Re: Engine Oil
« Reply #1 on: December 05, 2006 - 03:41:31 PM »
I heard rotella was switching to less additives
Re: Engine Oil
« Reply #2 on: December 05, 2006 - 03:46:51 PM »
Yep,
  Buy it now!!!
daves70
Re: Engine Oil
« Reply #3 on: December 05, 2006 - 03:50:00 PM »
What is the best oil and weight for my 440-SIXPACK ? I've been running 10w-40 Quakerstate.
Re: Engine Oil
« Reply #4 on: December 05, 2006 - 04:14:24 PM »
Dave,
  They are taking the zinc phosphate out of the oil that the older cars need for cam lubrication.  :dupe: The newer cars don't need it, so it is more environment friendly, I guess. No problem with your weight of oil.
Offline Mopar73340
Re: Engine Oil
« Reply #5 on: December 05, 2006 - 06:46:45 PM »
While the above is true, I just changed intakes on my 340 so I had a chance to look at the cam lobes. They all look great so I'm sticking with the Mobil 1 I've been using.   :2cents:
Offline TreeFrog
    • TreeFrog
Re: Engine Oil
« Reply #6 on: December 06, 2006 - 06:45:09 AM »
keeping the oil changed regularly should help a bit even if its the wrong oil (I would think)
But is there truely an over the shelf oil that is better for the older engines?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Re: Engine Oil
« Reply #7 on: December 06, 2006 - 12:40:21 PM »
Not sure if this is a repost, as I have not been on the forums recently, but I wanted to get people's input.  I have a flat tappet cam in my 383 I am waiting to install in a year or so, and I will be getting an updated cam for it anyways, as my old one does not match.  (BTW, if I have a flat tappet, couldn't I convert the engine to a roller cam anyways if I buy a kit?  It's a 1966 383 block and heads).  Read first, then respond!  Could be very important to us!
Anyways:
Your oil may be ruining your engine!
Oil issues and the modifications to oil formulas  il
There is a raging controversy on the recent modifications to oil formulations on almost all major oil companies products .
You'll find a lot about it on the MGCC UK site, look under TD/TF. It seems that at least in the USA, the oil companies have modified an old favorite ;Castrol 20W-50 by reducing the zinc compound. The zinc compound (ZDDP) protects rubbing surfaces like cams and lifters. This has been the subject of articles in the last 3 months of Skinned Knuckles magazine and numerous hot rod magazines.
The bottom line is that you must not try to break in newly rebuilt engines with these new oils, nor should you continue to run your old engines on the new formulation. .
Crane Cams has been very concerned about the new oil formulations ,and placed some information on their website ;
1. Lobe wear
2. Correct break-in lubricant.
"Use only the Moly Paste, Part Number 99002-1. It has the necessary zinc to help in Lobe wear ." That is what is included with the their cams. "This Moly Paste must be applied to every cam lobe surface, and to the bottom of every lifter face of all flat tappet cams."
Roller tappet cams only require engine oil to be applied to the lifters and cam." Also, apply the Moly Paste to the distributor gears on the cam and distributor for all camshafts."
For extra protection, Crane Cams recommends that an anti-wear additive ( with a significant amount of zinc ) be used . They recommend their Crane Super Lube, Part Number 99003-1.
OIL IS KILLING OUR OLD CARS
By: Keith Ansell, Foreign Parts Positively, Inc.
About a year ago I read about the reduction of zinc dithiophosphate (ZDDP) in the oils supplied with API approval that could affect sliding and high pressure (EP) friction in our cars. The reduction of these chemicals in supplied oil was based on the fact that zinc, manganese and/or phosphates reduce the effectiveness and eventually damage catalytic converters and introduce minute amounts of pollutants into our atmosphere.
A month or so ago I had a member of the Columbia Gorge MG Club bring a totally failed camshaft and lifters back to me that had only 900 miles on them!! I immediately contacted the camshaft re-grinder and asked how this could happen. They were well aware of this problem as they were starting to have many failures of this type. In the past, the lack of a molybdenum disulfide camshaft assembly lubricant, at assembly, was about the only thing that could create this type of problem. My customer has assembled many engines and had lubricated the camshaft properly and followed correct break in procedures.
This got me on the phone to Delta Camshaft, one of our major suppliers. Then the bad news came out: It’s today’s “modern” API (American Petroleum Industry) approved oils that are killing our engines.
Next call: To another major camshaft supplier, both stock and performance (Crane). They now have an additive for whatever oil you are using during break-in so that the camshaft and lifters won’t fail in an unreasonably short period of time. They also suggest using a diesel rated oil on flat tappet engines.
Next call: To a racing oil manufacturer that we use for the race cars (Redline). Their response: “We are well aware of the problem and we still use the correct amounts of those additives in our products”. They continued to tell me they are not producing API approved oils so they don’t have to test and comply. Their oils were NOT the “new, improved and approved” ones that destroy flat tappet engines! “We just build the best lubricants possible”. Sounds stupid, doesn't’t it, New-Approved but inferior products, but it seems to be true for our cars.
To top this off: Our representative from a major supplier of performance and street engine parts (EPWI) stopped by to “warn us” of the problem of the NEW oils on flat tappet engines. This was a call that the representative was making only because of this problem to warn their engine builders! “The reduction of the zinc, manganese and phosphates are causing very early destruction of cams and followers”. They are recommending that, for now at least, there must be a proper oil additive put in the first oil used on new engines, beyond the liberal use of molydisulfide assembly lube. They have been told that the first oil is the time the additives are needed but remain skeptical that the first change is all that is necessary. Their statement: Use diesel rated oils such as Delo or Rotella that are usually available at auto stores and gas stations.
This problem is BIG! American Engine Rebuilder's Association (AERA) Bulletin #TB2333 directly addresses this problem. I had a short discussion with their engineer and he agreed with all that I had been finding.
Next phone call was to a retired engineer from Clevite, a major bearing and component manufacturer. First surprise was that he restored older British Motor bikes. The second surprise was that he was “VERY” aware of this problem because many of the old bikes had rectangular tappets that couldn't’t rotate and are having a very large problem with the new oils. He has written an article for the British Bike community that verify all the “bad news” we have been finding.
Comp Cams put out “#225 Tech Bulletin: Flat Tappet Camshafts”. They have both an assembly lube and an oil additive. The telling sentence in the bulletin was “While this additive was originally developed specifically for break-in protection, subsequent testing has proven the durability benefits of its long term use. This special blend of additives promotes proper break-in and protects against premature cam and lifter failure by replacing some of the beneficial ingredients that the oil companies have been required to remove from the off the-shelf oil”.
Next question: Now what do we do?
From the camshaft re-grinders (DeltaCam) “Use oils rated for diesel use”, Delo (Standard Oil product) was named. About the same price as other quality petroleum based oils. They are not API formulated and have the zinc dithiophosphate we need in weights we are familiar with.
From the camshaft manufacturer (Crane): “use our additive” for at least the first 500 miles.
From General Motors (Chevrolet): add EOS, their oil fortifier, to your oil, it’s only about $12.00 for each oil change for an 8 ounce can (This problem seems to be something GM has known about for some time!).
From Redline Oil: Use our street formulated synthetics. They have what we need!
From our major oil distributor: Distributing Castro, Redline, Valvoline and Industrial oils: “After over a week of contacts we have verified that the major oil companies are aware of the problem”. “The representatives of the oil companies today are only aware of marketing programs and have no knowledge of formulation”. The only major oil companies they were aware of for doing anything to address this are Valvoline that is offering an “Off Road 20W-50” and Redline.
From Castrol: We are beginning to see a pattern emerging on older cars. It may be advantageous to use a non-approved lubricant, such as oils that are Diesel rated, 4 Cycle Motorcycle oils and other specified diesel oils.
Re: Engine Oil
« Reply #8 on: December 06, 2006 - 12:42:03 PM »
Last part:
Last question: So what are we at Foreign Parts Positively going to do? After much research we are switching to Redline Street rated oils and stocking the Castrol products that are diesel rated. Castrol, owned by British Petroleum, is now just a brand name. This is a difficult decision as we have been a dealer and great believer in all Castrol Products for over 40 years. We have been using Castrol Syntech oil in new engines for about 3 years so the cost difference in changing to Redline is minimal. The actual cost in operation is also less as the additive package in Redline makes a 1-year or up to 18,000 mile change recommended! Yes, it is a long change interval but with lowered sulfur levels and the elimination of lead and many other chemicals in the fuels there are less contaminants in our oil from the fuel, which is the major contributor to oil degradation. We will continue to offer the Castrol products but will now only stock the suggested diesel oils that they produce.
Too many things are starting to show up on this subject and it has cost us money and time. Be aware that “New and Improved”, or even products we have been using for many years, are destroying our cars as it isn’t the same stuff we were getting even a year ago.
For the cars that use “engine oil” in their gearboxes this may even pose a problem as these additives that have been removed could be very critical in gear wear. We will be using oil specifically formulated for Manual Gearboxes with Brass Synchronizers. The only oils we are aware of that fit the criteria are from General Motors and Redline.
If you have any additional input let us know. We need to let every flat tappet engine owner, i.e.: every British Car owner know that things are changing and we MUST meet the challenge.
Keith Ansell, President
www.ForeignPartsPositively.com
360-882-3596
Offline vinb
Re: Engine Oil
« Reply #9 on: December 06, 2006 - 04:13:22 PM »
Some interesting reading on engine oils in the Hot Rod June 2006. If you can find that issue.....
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
Re: Engine Oil
« Reply #10 on: December 06, 2006 - 08:54:22 PM »
ok...read all that. thanks
 Chryco  ...   what oil brand/weight would you use if you were me?
440 in California...maybe see an occasional high 40's start-up, but generally 50+ degree's in the winter.
Hot weather in the summer.
engine is broken in.
Redline synthetic 10-40 with the K&N oil filter?
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline 1 Wild R/T
Re: Engine Oil
« Reply #11 on: December 07, 2006 - 12:36:09 AM »
Currently the best solution is an additive with ZDDP, the EPA has mandated that ZDDP be removed from motor oil to prevent it damaging catalytic convertors...Diesel oils & automotive racing oils have continued to use it but they too are being phased out, currently additives are still avalible, one of the better ones is GM's EOS, I buy it by the case mail order from Scroggins & Dickey, they have are great price on it, I use a full bottle during cam break-in & a 1/2 bottle at every oil change...
http://www.sdpc2000.com/catalog/1016/products/584/GM-Engine-Oil-Suppliment-EOS-16oz-Bottle-.htm
Re: Engine Oil
« Reply #12 on: December 07, 2006 - 01:34:49 AM »
well we are all in the same boat & i am still trying to figure out what is best to use , it is not helping that oils liek Rotella that have always been a great oil are switching away from thew needed additives as well , right now Redline , Royal Purple have to be the best choice , I will not run 20-50 w oil or Valvoline racing would be a good choice
 the best solution for most is to use a good oil like Castrol or Valvoline in a 10-40 in non synthetic , or Redline , Royal Purple, Syntec, Mobil one ,in synthetic & add EOS or Comp Cams additive with every oil change
  • HvacMan
Re: Engine Oil
« Reply #13 on: December 07, 2006 - 10:30:51 PM »
thanks guys. I wasn't even aware there was a problem with the new oil formulas before this thread.
Hey I just noticed that Redline head quarters is a block away from my shop in Benicia !
I think I'll see if I can get a case direct.
Think I should switch the suregrip and 833 to their products also?
Eric
Bay Area California
Offline vinb
Re: Engine Oil
« Reply #14 on: December 08, 2006 - 03:11:41 PM »
A block away ?  I buy someone lunch and get a case or two......
