Author Topic: 340 6-Pack cam selection  (Read 753 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« on: December 06, 2006 - 12:49:57 AM »
I am getting ready to rebuild by 340 and I am planning on running stock X heads with a 6-Pack and stock compression (around 10 to 1), I will be running a 727 auto could run a stall if need be and 3.91 posi out back on 28 inch tires. Any suggestions on camshaft selection. I am considering mechanical and hydraulic, no roller cams. I will drive this car on the street primarily.
1996 Dodge Viper GTS Coupe
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: 340 6-Pack cam selection
« Reply #1 on: December 06, 2006 - 01:26:58 AM »
I like the performance of my Comp Cam XE268, in my 10:1 360.  Provides plenty of hp and still lets me run my stock converter with 3.23 gears.  I also got 17 mpg on the highway.  Just my  :2cents:
« Reply #2 on: December 06, 2006 - 01:36:08 AM »
Hyd -I would look at the Engle or Lunati VooDoo no need to replace the converter pick a cam in the range of the K 56 Engle
 solid - I use UltraDyne grinds
Offline moper
« Reply #3 on: December 06, 2006 - 07:57:03 AM »
Offline 72hemi
« Reply #4 on: December 06, 2006 - 09:20:42 AM »
At the moment I do not have a converter, I am going through a 727 and have not ordered my converter yet, so ordering a stall would not be  a problem. Thanks for the input.
