Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
VIN, Fender Tag and Broadcast Sheet Numbers
73 'Cuda Numbers ?
« previous
next »
Print
Pages: [
1
Author
Topic: 73 'Cuda Numbers ? (Read 2029 times)
IMNCARN82
Resident
LeDZeP
73 'Cuda Numbers ?
on:
December 07, 2006 - 07:26:51 AM »
When I got this car the seller said it was a #'s motor.I have a build sheet.It's hard to make out. 213718530623?62? BS23H3B373459. I checked what I could-It's a 73' 340 block. Cast #'s 2780930-340-1 The block stampings get very faint 3M 340 0223909 is as close as I can see. No fender tag. I believe the car to be from Mich. Isn't the stamping the sequence #? I'd just like to know before I get rough with her. I'll prob. pull it to save it if it is. It is now a 4 speed,I talked to a previous owner who has the #'s auto. Would it be worth it to try and get it? Shipping would kill me! I'd have to leave the 4 speed,I like it!!
Last Edit: December 07, 2006 - 07:36:40 AM by IMNCARN82
Logged
'73 340 5 speed,RMS,BAER,... "Supercuda" (O[ ]||||[ ]O)
'69 Dodge Charger 383,Auto (OiiiiiiiiiiIiiiiiiiiiiO)
13' Challenger R/T BlacktoP 6spd. (OO________OO)
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert "cuda bob"
DAYTONA
Sr. Member
Re: 73 'Cuda Numbers ?
Reply #1 on:
December 07, 2006 - 09:49:10 AM »
you have a '73-340 Cuda...it was built in Michigan(Hamtramack)
...the engine/vin number should be stamped on a small pad on the passenger side of the block just above the oil pan...it should probably read 3B373459....that number would also be on the trans....make the guy show you the # before purchase...
Logged
Alaskan_TA
Guest
Reply #2 on:
December 07, 2006 - 07:13:46 PM »
The number you found "3M 340 0223909 " is the engine serial number, (most of it anyway) not the VIN. Look where Larry mentioned for the VIN on the block.
Best of luck!
Barry
Logged
IMNCARN82
Resident
LeDZeP
Reply #3 on:
December 08, 2006 - 11:20:48 AM »
Thank you, I have checked those numbers.They are:3B378378. Not 3B373459. So this is not THE block? mayby a warranty? When I replaced the valve covers I found 360 cast on the heads. ANY feedback?
Logged
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert "cuda bob"
Alaskan_TA
Guest
Reply #4 on:
December 08, 2006 - 04:37:51 PM »
Warranty blocks do not have VIN numbers on them, so the engine is out of another car. The 360 casting was used on 340s and 360s, but the 340 heads had the larger valves installed. I am not sure if this is true for 1973 though, you may have to ask about it in the "engine" section.
Barry
Logged
IMNCARN82
Resident
LeDZeP
Reply #5 on:
December 10, 2006 - 11:41:16 AM »
The repeating number just struck me as odd that's all. I saw the 3B3 is this common? Thanks for all your help!!
Logged
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert "cuda bob"
Alaskan_TA
Guest
Reply #6 on:
December 10, 2006 - 11:58:55 AM »
3 - Last digit of model year, 1973
B - Hamtramck, MI assembly plant.
The next three is part of the sequential VIN, there would have been 100,000 cars that year with the 3B 3 from 300000 to 399999, so yes, it is pretty common.
T/Ake care,
Barry
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
73 'Cuda Numbers ?
