Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Compression
« previous
next »
Print
Pages: [
1
Author
Topic: Compression (Read 865 times)
nivvy
Guest
Compression
on:
December 07, 2006 - 11:39:56 AM »
I am currently running 906's with about 9.8 ot 1...I believe the 906's are 88cc
I am going to aluminum and want to get my compression up to about 11 to 1?
I dont need to change my pistons do I? or is the compression gonna come up to 11 to 1 because of the aluminum 78cc chamber?? Im sure gasket thickness matters as well...I dont know the formulas to figure this out
Logged
moper
Resident
Re: Compression
Reply #1 on:
December 08, 2006 - 11:18:44 AM »
http://kb-silvolite.com/calc.php?action=comp
It's fun to play with...
For piston dome ccs, you need to know the size (volume) of the valve releifs you have. This can be gotten from catalogs or websites.
I'd venture to gues your 906s are much larger than 88 ccs, unless they were CCd at one time and it's measured smaller. Most open chamber heads are in the 90-94cc range.
Also, most gasket bore sizes are for a .060 over 400 bore..which is 4.410"
And speaking of gaskets, you will want to figure what you need when running a composite gasket..most are .040-.045" compressed thickness.
have fun...
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Compression
Reply #2 on:
December 08, 2006 - 02:25:08 PM »
basically yes with the 10 cc smaller chamber the compression will jump approx 1 point of compression , gasket thickness will affect the exact result
Logged
nivvy
Guest
Re: Compression
Reply #3 on:
December 08, 2006 - 10:17:53 PM »
I just read an article in one of my car mags and it says stroking a motor will raise the compression as well.....I think I read entirely to much and get confused all the time....
I think CHYRCO should start his own Mopar Tech Magazine.....
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Compression
Reply #4 on:
December 08, 2006 - 11:13:52 PM »
yeah more than a few people have suggested me writing a book I was thinking about setting like a service manual using the same sections
Logged
moper
Resident
Re: Compression
Reply #5 on:
December 11, 2006 - 10:29:24 AM »
Changin nothing but adding stroke will raise it. But you change the pistons too..so that's out the window.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Compression
Reply #6 on:
December 11, 2006 - 05:14:53 PM »
once you stroke an engine everything changes & needs to be recalculated , the stroke increases & the rod lenght can go shorter , longer or stay the same & then the piston has to be adjusted to correct for shape & height to give specific quench & compression ratio
Logged
Aussie Challenger
Resident
In Kansas loaded for Drive to West Coast.
Re: Compression
Reply #7 on:
December 12, 2006 - 04:53:43 AM »
Goimg down a couple of cc's, 360 with approx .010" flat top piston down the bore, felpro head gasket and either a 302 or 308 head standard or just cleaned up give in the way of compression?? I am hoping to achive an end result of around 9.2:1.
Logged
moper
Resident
Re: Compression
Reply #8 on:
December 12, 2006 - 10:08:17 AM »
For that 360, you are close to 9.5:1 with .010 down in the hole flat tops, a .043 (fel pro) gasket, and a typical 74-75cc stock 308 chamber. Maybe higher with a good (meaning the small end of the factory 68-72cc spec) chamber.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Compression
