Author Topic: Flow Info  (Read 2441 times)
Offline firefighter3931
Re: Flow Info
« Reply #15 on: December 18, 2006 - 08:08:08 PM »
yes it will be dynoed
it has the 2355 piston zero decked , cometic gaskets .580 lift custom comp roller .245* @ .050 440 balanced going in a 69 RR with a 727
M1 single plane intake 3500 stall converter 2" headers & we will be creating a EFI system for it
Nice ! Is that an XE street roller grind ? I'm guessing it is based on the gross lift. Probably on a wide 112* for the efi ?
Should make some really good power numbers and idle like a stocker.  :2thumbs:
Ron
68 Charger RT street/strip Bruiser & 70 Charger RT 440-6pack the ultimate Cruiser
nivvy
Re: Flow Info
« Reply #16 on: December 18, 2006 - 08:27:31 PM »
Im surprised chyrco is putting a comp cam in there???
Re: Flow Info
« Reply #17 on: December 18, 2006 - 08:30:20 PM »
Customer had already ordered the cam , I had zero imput in the cam design
I think it was on a 110* CL
Re: Flow Info
« Reply #18 on: December 19, 2006 - 03:49:04 AM »
Thanks for the update. It will make some descent power and be very streetable. Looking forward to the numbers.  :cheers:
Ron
Re: Flow Info
« Reply #19 on: December 19, 2006 - 09:26:08 AM »
me too
