have the following parts in fiberglass from a race type cuda from the 70's.
pair of fenders have the lower mount holes are split. - 225
four pin lift off hood with a larger raised center scoop have chips and some attention needed at the corners. - 75
both doors are very nice without the hardware.
they do have an aluminum flat stock across to hold
the hardware. all was working nice. - 350
rear bumper has the pass corner split. -35
four pin lift off trunk lid with the clips and posts is very nice. - 125
dash board has one corner broken. - 90
K frame has the mounts cut off is solid no rust. - 35
steel wheel's some with tires holding air small bolt -
have three maybe four - 10 for all of them
plastic fuel cell. - 30
battery steel bottom frame. - 5
most of the parts have some kind of small repair needed from over
the years and would need resanding to paint of scratch's, chips ect.
the parts have the original stickers from the manufacture back in the day.
would work a good package deal for the whole lot.
*also a rear back half section with large tubs and square stock welded frame set up for
shocks and leaf springs with very nice alum complete trunk floor pan work and under rear
seat up and over the package tray with removeable inside panel with turn buttons.
The frames have the shackle mounts welded on with a frame mount at the rear seat torque boxes.
The heavy duty leaf springs are included.
The dana that was under it was 41" wide for 15" - 18" wide tires and 31" tall.
it has a battery frame and a fuel cell attached to the pan with a partial roll bar to the speaker shelf. - 400 obo
possible trade for E body parts and sheet metal.
Located in Michigan.
not sure about the shipping with the larger items?
could drive 2 hr +/- or more if gas $ -
*Please email me for I dont check here that often.
naderboy@hotmail.comsome pics on WWW.webshots.com
type in naderboy to see some folders.
