Author Topic: Stupid Small Block Question #248  (Read 868 times)
Offline asm74
« on: December 15, 2006 - 01:10:48 AM »
Are the timing covers from 91+ 5.9L magnum small blocks interchangeable with LA blocks?
I'm almost at my wits end trying to retrofit this serpentine system with my air gap manifold... The accessory bracket from the magnum covers the heater hose port on the manifold, and the magnum water pump has an unthreaded heater port that I can't seem to plug.  I'd like to have the denso alternator and the serpentine belt, if theres an alternative bracket to the standard 95 dakota one, I'd like to know about it.
Anyone need any 95 Dakota engine parts?
73 Challenger
Re: Stupid Small Block Question #248
« Reply #1 on: December 17, 2006 - 01:35:24 AM »
to the best of my knowledge yes the timing cover will swap
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #2 on: December 17, 2006 - 11:06:59 PM »
I was thinking the same thing, but I just did not want to be the first to reply.
« Reply #3 on: December 18, 2006 - 12:38:14 PM »
as I recall the bot pattern is exactly trhe same but all the accessories & mounts are different , for example the water pump is reverse rotation with serpentine belt & the alt is the smaller Nippondenso
Offline asm74
« Reply #4 on: December 18, 2006 - 01:14:35 PM »
Thanks, I'll try it out later this week.
Just to clarify, Im willing to give up the denso and the serp for the convenience of the LA accessories.
I ran into a nasty gotcha trying to swap the center sump LA style oil pans with the rear sump magnum pans.  The rear opening on the magnum is narrower than the LA, so the LA pan has a 1/4" or so gap at the rear crank. I've not been able to find a center sump magnum pan (supposedly in the van version of the 5.2 and 5.9) yet, may have to do some fabrication.
73 Challenger
« Reply #5 on: December 18, 2006 - 01:22:18 PM »
the LA pans had 2 different sizes at the rear , the smaller LA 318 & the larger LA 360 did you try both pans ?
