Author Topic: Fuseable Link  (Read 1340 times)
Offline 70challrtse
Fuseable Link
« on: December 16, 2006 - 05:14:40 PM »
Does anyone know who sells correct fuseable links for my 70 440 Challenger? I need one asap. Thanks.
Re: Fuseable Link
« Reply #1 on: December 16, 2006 - 05:33:28 PM »
I got one from Year One.
« Last Edit: December 16, 2006 - 05:38:26 PM by MEKrunner »
Re: Fuseable Link
« Reply #2 on: December 17, 2006 - 01:24:41 AM »
if you want to get creative with fusable link heat shrink & solder any parts store will have the fusable link wire
Offline 70challrtse
Re: Fuseable Link
« Reply #3 on: December 17, 2006 - 08:27:22 AM »
YO is out of stock, but thanks.
Offline heminut
Re: Fuseable Link
« Reply #4 on: December 19, 2006 - 01:58:12 PM »
:iagree: I bought some at Car Quest and made my own link.
1970 5.7 Hemi Cuda
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Fuseable Link
« Reply #5 on: January 10, 2007 - 05:28:49 PM »
its doubtful the one YO sells is correct in apearance.
Offline PlumCrazy
Re: Fuseable Link
« Reply #6 on: January 10, 2007 - 11:47:18 PM »
Chrysler used at least seven different manufactures who made harnesses in 1970, each one did things/used slightly different materials when they made their harnesses.  The ones that M&H makes for YO is based on what they have found to be the most commonly used and are correct in detail.
If you buy ANY harness including a fusible link and it is different from what you have you can call M&H and they will work with you to make the harness look like your original.  For example, most 70 FL have a blue square section where the lettering is, however I have found a few that have a yellow section instead of blue.  Both are correct, however the majority were blue, if you need it to be yellow I am sure M&H can make one for you with a yellow section.
Offline Got JOB
  • Member since 2-14-06
Re: Fuseable Link
« Reply #7 on: January 11, 2007 - 03:24:00 PM »
As posted by Chryco, you can get  the correct gauge fusible wire at local parts store, crimp an eyelet on one end and take apart the plug end and remove your old wire and recrimp or solder and reuse it. the tag will slide off your old link and put it on your new one before you finish both ends. I replaced two of mine that way.
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
