Author Topic: dipstick length (no joke;o(  (Read 1431 times)
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« on: December 17, 2006 - 12:11:19 AM »
Changed oil and filter today in the 440.
Put six quarts in her and the dipstick shows half a quart low (half way 'tween full and add). :dunno:
Wonderin if the dipstick could be the wrong one? Handle looks correct compared to pics I've seen of others.
The flattened blade portion is 22.5'' long including the wavey part at the top of flattened blade.
Could someone measure their big block dip-stick ( :nono:) or is this normal?
Finally, if it's the correct D.S. should I add oil till it's at the full mark? Stock looking pan.
Thanks
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Re: dipstick length (no joke;o(
« Reply #1 on: December 17, 2006 - 01:41:39 AM »
what # is stamped into the bottom of the oil pan ?
« Reply #2 on: December 17, 2006 - 05:25:26 AM »
My 440 only takes 5 quarts, so I think you might not have a stock pan.
  • HvacMan
« Reply #3 on: December 17, 2006 - 09:51:19 AM »
have not seen a #. Where would it be on the pan?
The pan doesn't look aftermarket or hang down.
I thought the 440-6 held six quarts?
If I have too much oil, that could be why I have had a tough time sealing the valve covers?
Eric
Bay Area California
Offline Oldschool
  • Member Since 9-05-06
« Reply #4 on: December 17, 2006 - 10:59:48 AM »
IF your pan is a 6 quart pan and that is the amount you put in it, the dipstick would show about 1/2 quart low AFTER you crank it and let the filter fill up with oil.  That is where the other 1/2 quart is and your dipstick length is fine.    :bigshades:     :cooldancing:
 and your level is correct
Ken  --  In Georgia
Offline cudabuyer
« Reply #5 on: December 23, 2006 - 05:51:01 AM »
nice 4 u to at least have a dipstick - SPEEDOMOTIVE in CA - built my aluminum hemi and forgot to insert the dipstick - 22k$ motor
& they have been as*&#holes with every other issue i have had
AVOID AT MAJOR  :pullinghair:
70 Dodge Challenger Convertible 6.1 Hemi
