Author Topic: Standard to Rallye cluster conversion  (Read 3282 times)
Offline hemi68charger
  • Charger Power!!
    • Houston Mopar Club Connection
« on: December 21, 2006 - 09:14:20 AM »
Hey Gang...
I have a friend who's starting the project of cloning out his 318 ragtop Chally into a clone 440 R/T.. I was curious, since I'm not the E-body guy like you dudes, what's involved in the conversion of his standard cluster to a Rallye cluster?
Thanks and Merry Christmas..
Troy
'69 Daytona 426 HEMI-727
'70 Superbird 440 - 4speed
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Standard to Rallye cluster conversion
« Reply #1 on: December 21, 2006 - 10:28:34 AM »
Well of course you need the rallye gauges with the switch panel, becuase the switch panels themselves are different. You will also need the rallye gauge heater control panel, because that too is different. The above gauge light panels are different, there are four lights instead of 3 on the rallye gauges, this you can choose whether or not you want to change it. As far as the wiring harness goes you can use the standard rallye gauge harness, but you will have to add a wire for the tach, lengthen a couple of other wires and change the wire for the oil pressure from going to an idiot light to plugging into a gauge. I think that is all I did when I converted mine. As a precaution check the amp gauge, they are prone to going bad and then frying the harness. Good luck and I hope this helps.
1996 Dodge Viper GTS Coupe
Offline ChallengerGary
    • Challenger Gary
« Reply #2 on: December 21, 2006 - 02:21:54 PM »
Troy,
Check with Tod, he'll know you need to do.
Gary
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline Challenger6pak
« Reply #3 on: December 21, 2006 - 09:03:25 PM »
I would say 72 hemi has it covered.  Give me a call if you need help when you get into it.  I have a couple out with the factory harness attached and can see what goes where.
« Reply #4 on: December 24, 2006 - 04:29:26 PM »
Just to add my 2 pennies here. You will need to change your oil pressure sending unit from one with the idiot light, to one the for the Rally gauges. You also need to plumb in power for the tach. The radio, or any power source that turns off with the ignition switch will work. You will need to find a constant power source for the clock.
Offline 4THECHALLENGE
« Reply #5 on: December 11, 2009 - 12:15:23 PM »
seems like this never ends...first i needed the gauges then the covers then the switch panels, then the rally bar and now the ac cover. geez ill never finish  :villagers:
« Reply #6 on: December 12, 2009 - 12:17:22 PM »
There's always those little details you don't notice until you get into it. :bricks1:
