Author Topic: Carter Therm quad  (Read 2771 times)
Offline TreeFrog
    • TreeFrog
Carter Therm quad
« on: December 21, 2006 - 09:56:51 AM »
Carter Therm quad what is the history reputation of this carb
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Re: Carter Therm quad
« Reply #1 on: December 21, 2006 - 09:23:07 PM »
they are a decent carb When they work , they are actually big enough But the Phenolic fuel bowl almost always crack warp or leak
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #2 on: December 21, 2006 - 10:24:31 PM »
Here's a nice link about Thermoquads.  Specs, history, and problems.
http://www.nybclub.org/m-r/carburetor/CarterThermoquadInformationPage.htm
Offline moper
« Reply #3 on: December 22, 2006 - 09:19:57 AM »
When working properly, the best carb around.
Finding one that is good, and getting the parts to tune it are the down sides. Check out Thermoquads.com Home of Demon Sizzler.
« Reply #4 on: December 22, 2006 - 01:16:19 PM »
Treefrog do you have a TQ now? Are you looking to restore to OE? If not you would be better off IMHO to get something else BUT if so I have sucessfully rebuilt a few & recently learned a new trick that will help with a bigger cam.
Offline Oldschool
  • Member Since 9-05-06
« Reply #5 on: December 22, 2006 - 01:21:59 PM »
I also have rebuilt a few and got them running and performing great.  All around great carb, imo.   Smallish primaries for decent fuel mileage, HUGE secondaries for great performance, and, oh yeah, don't forget that unforgettable sound of a wide open TQ on a well built Mopar engine....    :ylsuper:    :cooldancing:
Ken  --  In Georgia
Offline 57hemicuda
  • 5.7 hemi
« Reply #6 on: December 22, 2006 - 03:08:48 PM »
The only thing I've found the thermoquad good for,is to slide under the wheel to keep the car from rolling down the driveway
Offline 360 'CUDA
« Reply #7 on: December 22, 2006 - 03:19:06 PM »
We have had pretty good luck at the track with them.  Fastest time in the stock eliminator Aspen was 12:27 @ 109
Real easy to tune for weather conditions too
Offline 57hemicuda
  • 5.7 hemi
« Reply #8 on: December 22, 2006 - 03:45:46 PM »
The question is 360cuda,would you use it if you weren't forced to.I'm sure there are alot of guys who can make them work,to run the classes they race in,but there sure is alot better carbs out there
Offline 360 'CUDA
« Reply #9 on: December 22, 2006 - 04:22:07 PM »
I'm just saying they are not that hard.  I'm not in love with any particular air fuel metering system.
Offline vinb
« Reply #10 on: December 22, 2006 - 05:23:28 PM »
Hey 360cuda, are you racing a Stock eliminator ? I raced Mopar Stock/SuperStocker cars out here of the east coast for 25 years. T-Q is a great carb. When you have rules in class racing that's what your dealt with. As far as using another carb, of course I would use a Holley, parts are easy to get and easy to tune...
Offline 360 'CUDA
« Reply #11 on: December 22, 2006 - 05:31:28 PM »
We raced that Aspen for about 5 years from '87 to about 92ish. I still have all the engine and transmission stuff but the body is long gone.
I do still have the '72 'CUDA body we raced before and then after the Aspen and I have the engine setup out of the 10 second Vagrant.
Everything I race has a 360 in it. Hence my name
I have too much stuff and not enough cash
Offline TommySS
  • Forgot more than most will know...
« Reply #12 on: December 22, 2006 - 07:59:17 PM »
Run a compression check on all cylinders, and then do a cylinder leakdown test.  Please report the results for analysis.
While I wouldn't rule out a carb problem, indications to me are that you have a vacuum leak.  Could be from the carb-to-manifold gasket, a warped throttle plate or even a bum hose.
Hang in there.
Offline bb71challenger
« Reply #13 on: December 22, 2006 - 08:20:15 PM »
I have run a few and never had problems with them. When they are running right they are a great mix of economy and when those huge secondaries kick in, performance. Not my favorite but definitely nothing to beat with a stick.
*Brett*
Offline moper
« Reply #14 on: December 26, 2006 - 02:14:11 PM »
I love that sound. I've run them as much as I can. My Swinger FAST type car is getting one too. It sounds like the hood will get sucked down into there...lol.
There is no better carb IMO. The problem is finding one with a good base plate and intact middle. Then you need to find or make jets and stuff. But as far as street cars...they are #1 in my book. Just hard to find usable now.
