I thought I would give an update on what I've been up to. I have been working on the car just slowly.
I've got the license plate modification done and the tail panel is now primed.
Maybe I should explain
let me back up three weeks.
I started to clean up the rear license plate area and was complaining to some friends about the gap around the plate. Bad things happen when we start bench racing. After about 4 different versions of how to clean it up. I decided if you were going to do it right you would have to fill the hole and mount the plate from behind so just the numbers showed. So opening would be the size of the inside of a plate frame. With me on this? But I didn't want the work of relocating the fuel filler and making the plate swing in. I also didn't like the idea of using a fixed plate and filling the tank inside the trunk. My Dad comes up with the idea " Why don't you make it slide sideways"? Jumping forward
I bought a set of tool box drawer slides and used them to make a slide for the plate. The only trick is keeping the whole thing thin 5/8" to be exact. But It all fits. The plate and frame sits behind a fill plate and slide to the passenger side for fuel fill. I'm using a magnetic catch to hold the plate in the closed position. It works really slick. The hardest part was making the frame to hold it all in perfect alignment. The key hole for the trunk is in there also. Back to this weekend.
I spent a BUNCH of time making the panel perfectly flat ( At least a whole lot closer. ) I had to do some work to make the tail light fit as flush as I wanted. I think something got warped when I molded the tail light bezels in.
But it's all good now. I bought a white led light bar and mounted it to make sure I could light up the plate. It looks cool the light will hit the whole plate nice and even and not light up the frame or body at all!
I did a few other as well fixed a couple of flaws in the trunk lid and bumper. Gotta make it worth the time to get the gun out and set up for paint.
