Well I hit a Major set back.
Ok, so hears the problem. As you know if you have read any of this post. I have been working on the assumption that I will be using the A-580 auto stick trans. That is the trans that Chrysler puts behind the 6.1 L Hemi. It kinda makes sense, it was designed to work with that motor. I have driven one and it fun to drive too with the you shift it, auto-stick. I have known for for a while that no one has used this trans in a conversion yet. Not a huge worry I have done lots of conversions on other hard to install motors. I'm not afraid to make a custom harness and have had people write custom programs.
hears the problem. The short version. The motor and tranny along with all the other electronics talk though a network. In order to get the network up and get all the info I would need ( all the sensors) I would have to have most of the original car. IE dash computer column module. front control module, Dynamic stability control computer and as I under stand it even the climate control module! Even if I got all the modules and harness parts Most of them would error out because of how many inputs that would be missing. not to mention trying to find room for all that ****. This could be over come if the now gone Daimler would give up the coding for the network so that some software junky could write a program to "lie" to the computer and allow it to concentrate on making my car go in a forward direction. I've been talking to several people about this problem. S&P has been working on it to no avail. That's why no one uses this trans. Ok that was as Short as I could make it.
Options
1 Keep building the car and hope that someone will find a solution.
2 Use one of the other auto trans options that do work.
3 Change to a 5 or 6 speed stick.
4 Move the car into storage, and save some money, figure it all out later!
I've been doing a lot of research into options and will default to #1 until I get more data. But I don't think it is a viable solution. Just makes more painful when you bail.
I can use the truck 5 speed but its got truck gear ratios and no slap stick / auto-stick
I've heard good and bad about keisler kits. I can solve the two common complaints ( to low and vibration) by moving it up. Lots of room in my tunnel
A viper 6 speed would be fun
but ouch.
Good thing I got my seats installed it gives me a place to sit and think!
