Author Topic: factory tires '70 cuda  (Read 3755 times)
Offline 1970hemicuda
« on: December 21, 2006 - 10:58:44 PM »
I believe the factory rears for the '70 'cuda were F70/15s.  If so, does anybody know the overall diameter of those tires?
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: factory tires '70 cuda
« Reply #1 on: December 22, 2006 - 08:07:54 AM »
I don't think I have ever seen an F70 15 on a cuda. All cudas had the same size tire on all four corners except for the aar which had a E60 15 up front and a G60 15 in back. I think the only 70 series tire came on the E wide tires.
1996 Dodge Viper GTS Coupe
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #2 on: December 22, 2006 - 10:15:53 AM »
 :iagree: Atleast according to the factory brochure there was no F70-15 tire offered at all on any Barracuda/Cuda.
There was however an F70-14 tire and an F60-15 (Standard on Hemi) tire offered.
See this link for a pic of the brochure page with tire options.
http://www.stockmopar.com/_images/brochures/1970-plymouth-barracuda-brochure/original/1970-plymouth-barracuda-brochure-11.jpg
« Reply #3 on: December 22, 2006 - 11:05:38 AM »
Excellent!!! Many thanks ... F60s it was, then!  I'm sure I can find the diameter online somewhere ~
« Reply #4 on: December 22, 2006 - 01:10:28 PM »
F60s?
Wowzers!  I just noticed your name here!   :faint:  :worshippy  :worshippy  :worshippy
« Reply #5 on: December 22, 2006 - 01:14:11 PM »
Check out the chart here:
http://www.musclecarclub.com/library/tech/tires.shtml
and this is handy too.
http://www.miata.net/garage/tirecalcold.html
"Alpha Numeric: G78-14
The "size designation" is a combination of one letter and four numbers and is a three-part code. The letter denotes the sidewall-to-sidewall width of the tire; the two numbers grouped with the letter refer to the height-to-width ratio; and the numbers following the dash indicate in inches the diameter of the wheel rim the tire will fit. Therefore, the above tire is "G" in width, and the sidewall height is 78% of the width. It is designed to be mounted on a 14" wheel."
Offline GMachineDartGT
« Reply #6 on: December 27, 2006 - 10:01:20 AM »
f60s are 26 inches tall...
