Author Topic: To minitub, or not to minitub, that's the question  (Read 2864 times)
Offline Ornamental
  • Oslo, Norway
« on: December 22, 2006 - 07:46:26 AM »
I'm currently in the process of deciding how my Challenger is going to be, and i need some advise.
For a 500++ HP engine, will the stock wheel wells house large enough tires to get the power to the ground, or will i better have a minitubbing job done in the rear?
If a minitubbing is the way to go, what tiresizes should i consider?
Panther Pink '72 Challenger Rallye.
Grey '70 Challenger R/T
-There are two kinds of pedestrians: The quick and the dead.
***Per Arne***
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: To minitub, or not to minitub, that's the question
« Reply #1 on: December 22, 2006 - 08:02:23 AM »
The stock wheel wells should be fine for 500 hp. I am running 275 60 15 tires on the back of my Challenger. Just get some good tires in that size. By the way I am running a 15 x 8 rim with 4.5 inches of backspacing.
1996 Dodge Viper GTS Coupe
Offline Ornamental
  • Oslo, Norway
« Reply #2 on: December 22, 2006 - 08:19:24 AM »
Thanks, particulary for the backspacing info! I did'nt think about asking that!
At which point should one better minitub?
Horsepowerwise, how insanely over the top will one have to be to need minitubbing?
***Per Arne***
Offline ShelbyDogg
« Reply #3 on: December 22, 2006 - 09:41:58 AM »
It all depends on the look that you're after.  If you want the Pro-street, BIG MEAT look, then go ahead and mini tub it. That is the easiest way to get HUGE tire into that fender, for that great rear wide tire look.   Just remember that the car will be harder to sell after being cut up.
Offline ChallengerGary
    • Challenger Gary
« Reply #4 on: December 22, 2006 - 02:18:46 PM »
Considering that the 10.5" tire class of racing regularly features cars in the 8's, it's really not a mtter of tire size to horsepower.  It's a matter of maintaining traction in which the type of tire is as important (if not more so) than the size of the tire.  If you are worried about traction from a racing standpoint, consider your leaf springs, pinion snubber and tire construction (not necessarily width) as the key components.  If you are talking about the cool factor involved with fat tires, I say Tub it - but remember it will hurt resale value.  Personaly, I LOVE STEAMROLLERS  :2thumbs:
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline 360 'CUDA
« Reply #5 on: December 22, 2006 - 02:49:25 PM »
Minitubbing works alot better in the earlier B-body and A-body cars
With the E-bodys the frame comes real close to the wheelwell at the back anyway so go with just the spring relocation kit or go hog wild and backhalf the car.
Minitubbing just doesn't give you more then 3/4s of an inch extra and you still have to move the springs in more to take advantage of it
« Last Edit: December 22, 2006 - 05:15:06 PM by 360cuda »
Offline 4Cruizn
  • HEMI FISH
« Reply #6 on: December 22, 2006 - 02:50:41 PM »
I personally would not mini tub an e-body . . . love the fat tires but lose too much in value.  JMO   :grinyes:
Offline Ornamental
  • Oslo, Norway
« Reply #7 on: December 23, 2006 - 12:45:18 AM »
Thank you for great answers! :2thumbs:
Even if i like the look of slightly fatter tires in the rear, the wheel wells will stay as they are.
The looks alone won't justify the cost of minitubbing.
...Just remember that the car will be harder to sell after being cut up.
...- but remember it will hurt resale value...
Selling the Chally?
The robot Bender in the Futurama series said it best: "There's an old computer saying: Does not compute" ;)
***Per Arne***
    • Challenger Gary
« Reply #8 on: December 23, 2006 - 06:14:16 AM »
Sounds like you've solved your problem  :ylsuper:
