Author Topic: Another color question  (Read 1038 times)
Offline AMXguy
« on: December 22, 2006 - 11:29:43 AM »
I'm pretty sure the top plate the hood pop up spring is supposed to be body color but what abour the vertical brace that bolts under it? black or body color I've seen both?  thanks
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline Challenger6pak
Re: Another color question
« Reply #1 on: December 22, 2006 - 11:41:45 AM »
That would depend on whether your car radiator core support was blacked out or not from the factory.  Most I have seen are body color.
Alaskan_TA
« Reply #2 on: December 23, 2006 - 06:46:28 PM »
Body color, and then the front part and sides blacked out.
Barry
Offline AMXguy
« Reply #3 on: December 23, 2006 - 07:09:54 PM »
That's what it looked like when I stripped it, anything else blacked out behind th grill other than that?
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #4 on: December 24, 2006 - 09:08:17 AM »
I heard or read (fron Lord Galen) that it is the same with this as the cowl area...bright colored cars had this painted black, dark colored cars (black, ivy green, jamaica blue, etc.) had this painted body color.
« Reply #5 on: December 25, 2006 - 06:11:14 AM »
Alaskan_TA
« Reply #6 on: December 25, 2006 - 04:32:26 PM »
The engineering drawing for the radiator suport blackout can be seen here;
http://www.hamtramck-historical.com/images/engineeringDrawings/ei003.jpg
Every car I have seen has black overspray on the top radiator support bar.
It also states that TX9, EF8 and EB7 cars were exempt from the blackout paint, but I have seen a TX9 car and an EF8 car that both had it.  :dunno:
If you have a car that is one of those colors and it has the blackout paint, them but it back when you restore it.  :wave:
T/Ake care,
Barry
