Author Topic: Rear Sway Bar  (Read 901 times)
Offline MR291
Rear Sway Bar
« on: December 24, 2006 - 01:03:51 PM »
Hi all,
I am installing a stock rear sway bar on the Cuda.  Does anyone have a set of meaurements so that I can bolt it into the right place.  A measurement from the shock crosss member to the sway bar bracket which hooks to the frame rail?  Any suggestions would be appreciated.
Thanks.
Jerry
Re: Rear Sway Bar
« Reply #1 on: December 24, 2006 - 04:56:15 PM »
Jerry,
  I wish I could help you here. It all should be pretty simple until it comes to drilling the holes in the frame rail. I did this all once upon a time, and I can't remember all the parts off-hand. If you get stuck, maybe you can post a pic of the offending part(s), and that will jog my memory. Remember, I'm a Chally guy, but they both should be the same.
EDIT: Putting the brackets on the frame rail should be the last step. Get it set up under the leaf springs first.
« Last Edit: December 24, 2006 - 04:58:03 PM by MEKrunner »
