72 Cuda g-machine - 2016 update
Author Topic: 72 Cuda g-machine - 2016 update  (Read 221067 times)
Offline ragtopdodge
Re: 72 Cuda g-machine - depressed... broken already
« Reply #450 on: December 21, 2012 - 03:57:36 AM »
Doesn't the detonation sensor automatically retard timing?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline Travis72
« Reply #451 on: December 21, 2012 - 02:58:20 PM »
Thanks all for the postive comments.  It helps.
Ragtopchally, on a stock PCM yes it would.  Unfortunately the FAST XFI doesn't use the knock sensors
Haddixj, send me a PM with your email address and I'll send you some pictures of the gauge setup. There's not much too it and it would be easy to recreate at home.  I wish I had taken a better video than this (and not had my finger covering part of the lens, I'm still getting used to the iPhone...lol) but here's a shot of the dash on the dyno. If you watch it in high def and full screen you can see the car hits 120 mph in 4th.
IMG 0055
Travis
72 Cuda
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #452 on: December 21, 2012 - 05:42:22 PM »
Travis this sucks as I already said I'm as sick as you apon  hearing that your motor broke so early.
I have always said as soon as I find a good excuse to put a strocker crank in my car I would, looks like I'll be learning from you on this one.  :popcorn:
Please keep us updated.
Go Fast & Have Fun...
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #453 on: March 24, 2013 - 05:40:10 PM »
any updates travis? i noticed where you have posted some but no updates on the car. or i missed one?
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline Travis72
Re: 72 Cuda g-machine - running again
« Reply #454 on: March 25, 2013 - 02:01:55 AM »
Yeah the new engine is installed and I'm slowing getting it dialed in.  I have about 70 miles on the new engine.  It's now a 426 ci stroker with ported heads and a larger cam.  It took me awhile to get the clutch bleed and its still not as good as it was, so I'm going to try and bleed it again now that I've put some miles on it.
With the larger engine, I bought a set of 42 lb injectors because I was worried about running out of fuel with the stock injectors.  So because of that the whole fuel curve needs modified. I’m trying to take it slow and not screw it up again, so I hired a guy who's a FAST expert and teaches EFI classes.   When I first got the car running he logged in remotely to my laptop and made real time changes while I was on the phone with him.  It was good because he would explain what each of the setting do at the same time.  So since then I’ve been driving the car under specific conditions (for example, holding 2000 rpm for 30 seconds, then 2200 rpm for 30 seconds etc.) while data logging. I send the tuner the log file and he sends me back a new tune.  I'm on the 9th revision now and it’s getting dialed in however there are still areas of the fuel curve that need work.
On Friday for the first time I did some full throttle runs from 2000 rpm to 5300 rpm in 3rd gear.  The car pulls really, really hard.  That's from ~30 mph to ~85 mph and from the data log it took 6 seconds.  Once it’s all tuned it should be an easy 475 rwhp.
It actually has a slight lope in the idle now with the larger cam.
IMG_0481
Here's how it sounded with the stock 6.1L
IMG_0049
The engine looks the same externally so no new pictures to post.  I’ve been meaning to take some video when I’m out driving the car, but I’ve been focused on other things.  I’m just glad to have it running again.   :)
While the engine was out I removed the Nu-Relics power window kit (same as XV’s kit) and installed an Electric Life power window kit.  The Electric Life kit works good.  For whatever reason I could never get the Nu-Relics working on the passenger side and so I’m much happier with the Electric Life kit.  I took a bunch of pictures of that and some video and I’ve been meaning to make a power window post.  I might be able to get to that later in the week.
Travis
72 Cuda
« Reply #455 on: March 25, 2013 - 06:53:58 AM »
Good to hear it's running again! :clapping: :2thumbs:
Offline jedg
« Reply #456 on: March 25, 2013 - 11:10:15 AM »
Right on!!! Glad to hear it's back on the road Travis.
Offline ragtopdodge
« Reply #457 on: March 25, 2013 - 12:30:22 PM »
So as a post-morten to the old engine, you were running way too lean for too long?  What A/F ratio is ideal?
06 300c SRT8
04 2500 QCLB 4x4 HO
    • THE DODGE BOYS
« Reply #458 on: March 25, 2013 - 10:34:24 PM »
Awesome news Travis can't wait to hear your final thoughts on the new motor
Offline Travis72
« Reply #459 on: March 31, 2013 - 08:47:31 PM »
Ragtop... it was way too much timing.  These new hemis only like 22 - 24 max.
Just an update for those of you that have read the whole thread including the power window kit saga.  Here's what I ended up doing:
http://www.cuda-challenger.com/cc/index.php?topic=91560.0
Travis
72 Cuda
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #460 on: April 04, 2013 - 06:18:38 AM »
Looking good Travis , Glad to see you have it running again. Bet your loving the torque from that 426 stroker.  :woo:
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #461 on: April 04, 2013 - 09:19:49 AM »
 :drool:  Great to see it up and running!  That is a sweet looking car!  :grinyes:
« Reply #462 on: June 04, 2013 - 05:15:04 PM »
Hi Travis.. Any new  updates ? Hows that stroker hemi running?
Offline Travis72
« Reply #463 on: June 11, 2013 - 02:12:53 AM »
Hi John,
New engine is running good.  Full throttle tune is pretty close.  The car is scary fast now.  I'm anxious to get it out on a track.  I've been driving it like once a week, but I really need to get the AC installed so that I can drive it more.  That will probably be my next project.
Plus I still have a ton of little things to do and fix/clean up.  I had the dash apart for a while and I sent my dash switches to Jim (Slotts) to have him rebuild them.  He did a fantastic job and now the wipers actually work.  So I cleaned up the wipers and installed them.  About the only other significant thing I've accomplished is I installed 6-point harnesses in the car for the track.  I'll use the 3-points on the street.  The Recaro seats have a pull out leg extension, so when I had the seats upholstered I had them add in a slot for the crotch strap to pass through.  It worked out good and when not using the harness it allows me to push the crotch strap down out of the way.  I used the same normal seat belt locations for the lap belt.
Travis
72 Cuda
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #464 on: June 12, 2013 - 08:45:17 PM »
Lets get that Go-Pro cam installed and get some video!  great job! :2thumbs:
