72 Cuda g-machine - 2016 update
Author Topic: 72 Cuda g-machine - 2016 update  (Read 221058 times)
Offline Srobinson4
Re: 72 Cuda g-machine build up (lots of pictures)
« Reply #75 on: January 07, 2008 - 04:44:30 PM »
What does "G" machine mean?   :clueless:
Offline Carlwalski
« Reply #76 on: January 07, 2008 - 04:53:02 PM »
As far as I'm aware G = G-Forces. :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Srobinson4
« Reply #77 on: January 08, 2008 - 12:38:21 AM »
Thanks for the knowledge.
SRR
« Reply #78 on: January 08, 2008 - 07:13:44 AM »
g-machine being one that can not only accelerate brutally, but also corner and stop equally as well.
« Reply #79 on: January 08, 2008 - 10:29:13 AM »
Nice work Travis.
My friend has one of those body nail weld guns he's going to let me use. Good pics for me to see before I do that to mine.
Offline jvike
  • Pro-Touring Cuda
« Reply #80 on: January 08, 2008 - 11:24:44 AM »
A g-machine should pull 1. G in acceleration, braking force, and lateral G..
Offline conv340
    • Myspace CaMopar
« Reply #81 on: January 09, 2008 - 01:34:54 AM »
I know how you feel I think my car came from the same school of hard knocks. Body work is an art form unto itself one I don't really want to ever master.  :swear: Bondo on Bondo off.  :eek4: Looking real good  :thumbsup:
Two models, Two makes, One year, One body.
Offline Travis72
« Reply #82 on: January 09, 2008 - 02:24:42 AM »
Thanks for the comments all, I appreciate the support.   :2thumbs:
Yeah on the stud gun, once the studs were in place, I found it helpful to lock the slide hammer on the stud.  Then use a pulling force on the slide hammer/stud with one hand then lightly tap down the high spots around the dent with the other hand.  On my doors because it's a 72 it has the door crash bar reinforcements so I couldn't get a dolly on the back side of the dent.  Anyway just another way you can use the stud welder and slide hammer.
Yeah I hear you conv340.  My doors are starting to look like that.  I think part of my problem was not applying the body filler over a large enough area, meaning extending beyond the dents themselves.  It's also a pain trying to make the main body line look nice.  I bet it really sucks on a Challenger.  All professional auto body guys must have Popeye forearms because after 4 or 5 hours of sanding, I'm really sore... either that or I'm a wimp.   :pullinghair:
Travis
72 Cuda
Offline go-fish
« Reply #83 on: January 13, 2008 - 10:25:55 AM »
Travis, you doing your rear like Conv340?
Offline Travis72
« Reply #84 on: January 13, 2008 - 10:57:38 PM »
Yep.  I'm going to copy most of what he did (moving the lower links in, bracing across the two upper bar mounts and bracing the shock mounts).  He came up with a pretty slick setup!
Travis
72 Cuda
Offline go-fish
« Reply #85 on: January 14, 2008 - 08:59:52 AM »
Me too. I am glad he did it first. I am also planning on welding all of the brackets onto the car. I know it makes it more permanent but it is so much safer. I am usng coil-overs, I forgot are you?
Offline Travis72
« Reply #86 on: January 15, 2008 - 01:19:55 AM »
Yeah I'm with you, I'll be welding as well.  I wouldn't trust it with just the self tapping bolts to hold everything together.  Yep coil overs as well from Bill Reilly.   :thumbsup:
Travis
72 Cuda
Offline go-fish
« Reply #87 on: January 15, 2008 - 09:17:19 AM »
How are you reinforcing the two upper bar mounts that attach behind the seat? Please show a pic if you have one.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #88 on: January 18, 2008 - 07:38:00 PM »
 :wow:that a cool ride... :cooldancing:
Have you tested the xv brace with the 6.1 installed? I wonder if it will clear the intake for the efi they use a differant manafold on there stuff.
Also what are you using for headers?
Go Fast & Have Fun...
Offline hemiken
« Reply #89 on: January 18, 2008 - 08:42:27 PM »
 :cooldancing: Like looking cool man  :cooldancing:
