In parallel with this, I've been working on replacing the passenger side quarter panel. So yes basically every panel on my car has some sort of body damage. I'm assuming that back in the 70's this thing must have taken a hard hit to the quarter panel. You can see how mangled the outer wheelhouse is and how it ripped the c-pillar (see pic 3882). Someone had taken a full quarter and instead of melting out the factory lead and replacing it correctly, the brazed and riveted it on top of part of the factory quarter. So they basically didn't want to deal with the spot welds I guess
The brazing has no strength and once the edge came loose it basically un-zippered. Scary. In picture 3825 below, the bare metal piece is the factory quarter, which you can tell because it still has little spots of the factory white paint. You can see the brazed seam up above it.
No welding just brazing everywhere. Even the ripped c-pillar had brazing where they tried to repair it. I went ahead and made a little patch panel for the c-pillar and welded it in with a lap weld. I was going to butt weld it then figured why bother since no one is going to see it. It probably wasn't necessary from a strength standpoint to fix the c-pillar but I feel better now that I did it.
Travis
72 Cuda
