Author Topic: 340 Pistons ??  (Read 4656 times)
Offline farmboy70
340 Pistons ??
« on: December 26, 2006 - 03:11:09 PM »
We removed the heads and found it to be 30 over on my Cuda engine. The numbers on the piston is L 2385 Can anyone identify the manufacturer?
There seems to be very little ridge.
I want to find out as much info on them as I can to decide if I should reuse them. Thanks in advance for any info.
Offline dragfish
Re: 340 Pistons ??
« Reply #1 on: December 26, 2006 - 04:33:26 PM »
Pistons are a TRW .They are a factory stock replacement for a 72-73 340.
Offline 422STROKER
  • Member Since 6/3/06
Re: 340 Pistons ??
« Reply #2 on: December 26, 2006 - 04:34:29 PM »
I agree, I got those in my 340 as well---8.5-1 comp.
Tom
Tom
Re: 340 Pistons ??
« Reply #3 on: December 26, 2006 - 05:01:54 PM »
The Speed Pro L2316 would be the factory 68 piston 10.1:1 comp
Offline farmboy70
Re: 340 Pistons ??
« Reply #4 on: December 26, 2006 - 06:03:17 PM »
Thanks everyone. :2thumbs:
 I had kind of hoped these were the higher comp ones , so I would not have to replace them to get the comp up. Oh well. :banghead:
Re: 340 Pistons ??
« Reply #5 on: December 26, 2006 - 09:18:35 PM »
you will have to replace them to increase compression
Offline jvike
  • Pro-Touring Cuda
Re: 340 Pistons ??
« Reply #6 on: December 27, 2006 - 08:17:17 AM »
I agree, 72-74 replacement pistons would be L2385, like the ones I got.  :walkaway:
Offline farmboy70
Re: 340 Pistons ??
« Reply #7 on: December 27, 2006 - 09:46:53 AM »
What would the compression be if I used the 308 heads?
Offline farmboy70
Re: 340 Pistons ??
« Reply #8 on: December 30, 2006 - 09:04:09 AM »
Here are some pictures of it tore down .The pistons are 30 over, bearing shows it was rebuilt in 1981. The heads appear to have larger valves, we will measure them when we get them out. If the valves are 2.02s which heads would be better the 308's or the stock heads with bigger valves?
Re: 340 Pistons ??
« Reply #9 on: December 30, 2006 - 11:52:21 AM »
ported 308 heads are good for 41 RWHP over the X or J casting the compression will remain the same with either head as the conbustion chamber volume is the same
