Author Topic: Pitman Arm Question  (Read 1017 times)
Offline Cranker
Pitman Arm Question
« on: December 27, 2006 - 02:23:32 PM »
Wht are the differences between 72 and 73 pitman arms? I am thinking it is the spline size. In all of my catalogs at work (moog,acdelco) they list them for a 73-74 but nothing earlier. I am going to put a new gear on it any way and have both of them avalible to me (actually in stock). If they are different can i go with a 73 gear and pitman and still use my other steering components to work?
NEW INFO:
Okay the difference according to the two different gears that i have in stock is that the 72 pitman shaft splines are 1.10" and the 73 is 1.20" that is the only difference that i can see. The steering shafts are both .62". My parts catalog from moog and acdelco both list them as 70-72 and 73-74. So will the 73 gear and pitman work with the 72 steering. only reason is i can get the 72 pitman arm from my work and save me money if not then i will get the gear box from me and a pitman arm from someone else.
 Thanks Crank
« Last Edit: December 27, 2006 - 02:43:03 PM by Cranker »
72 rally chllenger completly disassembled. Estimated time of restomod 2016!!
Offline Katfish
  • 70 Challenger
Re: Pitman Arm Question
« Reply #1 on: January 02, 2007 - 05:10:35 AM »
I believe the only difference is the diameter of the steering shaft / pitman arm as you mentioned.  I converted my 70 to the police style box from a 80's Diplomat to get the firm feel.  Only other thing I had to change was to get a pitman arm for a 74 E-body.
All other steering components were left stock.
« Reply #2 on: January 02, 2007 - 10:54:22 AM »
somewhere between 71-73 the pitman arm reverses the 70-71 style has the centerlink under the pitman arm , 73-74 had the center link above the pitman arm with the pitman arm being longer to reach under the center link
