Author Topic: My 74 'Cuda  (Read 8658 times)
Offline 74 340 4speed
Re: My 74 'Cuda
« Reply #15 on: February 22, 2007 - 05:34:21 PM »
The car looks and sounds cool.Did you check Your firewall harness plugs Probably some good corrosion there.terry
No, I didn't.  Thats something that I need to do.  Thanks!
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10  350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
Offline farmboy70
Re: My 74 'Cuda
« Reply #16 on: February 22, 2007 - 05:35:31 PM »
On a 74 I believe it is attached to the main lug on the starter relay beside the battery, probably blue.
Re: My 74 'Cuda
« Reply #17 on: February 22, 2007 - 05:35:36 PM »
I had a Charger with this issue once & I know that others here have found similar problems with the steering column harness connections. The wires & teminals can look ok but the terminals get pushed a little too far in the plug & don't connect.
Re: My 74 'Cuda
« Reply #18 on: February 22, 2007 - 05:50:02 PM »
Is this it? I circled it in paint with a yellow line, but its kind of  hard to see.  I hope that's it.
Andy
Re: My 74 'Cuda
« Reply #19 on: February 22, 2007 - 05:56:41 PM »
I don't think so.. mine is on the back side of the relay , not going to the battery, I'll get a pic for you in a few min.
« Last Edit: February 22, 2007 - 06:21:41 PM by bullitt99 »
Re: My 74 'Cuda
« Reply #20 on: February 22, 2007 - 05:57:39 PM »
Thanks for the help bullitt99.
Andy
Re: My 74 'Cuda
« Reply #21 on: February 22, 2007 - 06:13:08 PM »
Here you go.... I'm afraid you may not have a fuseable link installed...DANGER
Offline farmboy70
Re: My 74 'Cuda
« Reply #22 on: February 22, 2007 - 06:19:10 PM »
Is that red wire going to the bulk head connecter? If it is follow it and see if the connections is bad. That should be where the link was. That needs to be replaced with a fusable link. It looks like you have no overload protection and could have a fire.
Re: My 74 'Cuda
« Reply #23 on: February 22, 2007 - 06:27:30 PM »
You can get a replacement fuseable link at NAPA, most parts houses you buy in bulk & maker your own
Item#: BEL784690
Price: $3.99
Re: My 74 'Cuda
« Reply #24 on: February 22, 2007 - 08:28:06 PM »
I bought a fusable link from Advance Auto Parts tonight.  I will try it tomorrow afternoon.  There is no fusable link in the wire on my car that looks like the one you have pictured.  I will trace this wire for a short, install the fusable link, then go from there.  The car ran fine for about 10 minutes on monday, but now it won't do anything.
Andy
Re: My 74 'Cuda
« Reply #25 on: February 25, 2007 - 07:31:47 PM »
Okay, I traced the wire that went from the starter relay to the fuse block, and it looked good.  So, I removed this part of the wiring from the fuse box, put some di-electric grease on it and put it back.  Next, I put a new terminal end on the wire going to the relay.  I got in the car and turned the key to the on position and saw that the charge/discharge gauge moved.  I then tried to start the car.  It turned over a few times and cranked right up.  :grinyes:  However, it did not run as smooth as it did before.  I could not get it to idle and it was trying to spit back through the carb.  My question is, what should be the timing on a motor like this?  340, huge solid lift cam, 11-13:1 compression(not sure on this, motor was built before I was born), aluminum dual plane intake, 750 holley, electronic ignition.  I think that it may be timing related.  Where can I get a timing tab, and where should it go on the timing cover?  My engine does not have one on it.   I will pull the plugs the next chance I get and make sure that they aren't fouled out.  If they are, then that is an easy fix.
Andy
Re: My 74 'Cuda
« Reply #26 on: February 26, 2007 - 06:57:24 AM »
You will find that the timing marks are on the timing chain cover drivers side on post '69? motors.
What is your fuel source? I would be suspect of clogged filter & or trash in the carb.
Are you now getting 12+Volts to the ballast resistor? Local guru did a diagnosis on his OE harness & was loosing a volt or so at each connection net effect was about 9volts to the ignition.
« Last Edit: February 26, 2007 - 07:01:03 AM by bullitt99 »
Re: My 74 'Cuda
« Reply #27 on: February 26, 2007 - 08:47:36 AM »
bullitt99:
My motor has the water pump exiting to the driver's side of the car.  The inlet and outlet of the radiator are both on the driver's side of the car.  This means I have a pre-69 engine, right?  The radiator i'm using is a 22" core unit that was originally in a super bee or road runner.
My fuel system is as follows:
New fuel tank, cleaned sending unit, new sock on sending unit, new fuel line, new fuel pump, new clear see-through fuel filter, new dual line for carb, and a new 750 holley, mechanical choke.
I have not rechecked the voltage at the ballast yet.  I think that the plugs may be fouled because I know a good bit of gas was pumped through the engine trying to get it to crank over this week.
Andy
Re: My 74 'Cuda
« Reply #28 on: February 26, 2007 - 12:06:00 PM »
I'm not sure of the exact year that the change was made but the eary 340s were set up like yours with the pump exit on drivers side which put the timing marks on the passenger side but I believe it is also possible to install an older style pump on the newer motors in which case the marks will be obsured. Timing tape may be the answer
http://www.wyckoffchryslerparts.com/dadetitap4.html
Re: My 74 'Cuda
« Reply #29 on: February 26, 2007 - 01:44:12 PM »
Thanks a bunch!  I'll look into that for sure.  Timing tape would be pretty easy to install too.
Andy
