Author Topic: Manual Steering Column  (Read 1724 times)
Offline CUDA JAS
  • vroooooom!
« on: December 31, 2006 - 08:46:06 PM »
Looking for a manual steering column for an E-body, 70-74, floor or column, driver condition.
As long as the main shaft is in usable condition I am interested! :bigsmile:
Jason!
74 'cuda 360/727
Just call me a gearhead!
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Manual Steering Column
« Reply #1 on: December 31, 2006 - 11:57:03 PM »
Why don't you just use the adapter which allows you to use a ps column with a manual unit.  That is what I am using and it fit and works great.
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: January 01, 2007 - 04:03:36 PM »
Well I have manual steering and a manual column, but it looks like some one cut and welded the main shaft at some point in time.  Possibly to convert from power to manual, not sure.
I would like to replace the column or at least that shaft, just to be on the safe side.
If I can not find a decent used column, then I may look at using a power column and the adapter, but that is a little more than I would like to spend right now.
Jas
« Last Edit: January 01, 2007 - 04:26:06 PM by CUDA JAS »
74 'cuda 360/727
« Reply #3 on: January 01, 2007 - 09:08:02 PM »
I gotta power shaft you can slide out the 3" or so. 25 bucks plus shipping.
Offline ShelbyDogg
« Reply #4 on: January 02, 2007 - 05:47:39 PM »
CudaJas,   Did you try extending your column shaft out?   Most of the shafts will pull out or push in to the correct length for manual or PS.  You just need to change the coupler on the end.  Some of those shafts look welded on the end from the factory.
Offline jvike
  • Pro-Touring Cuda
« Reply #5 on: January 05, 2007 - 09:10:38 AM »
There is a 4 speed cloumn on ebay now...
Offline CUDA JAS
  • vroooooom!
« Reply #6 on: November 16, 2007 - 08:09:18 AM »
Still Looking...
Jas
« Last Edit: November 16, 2007 - 11:07:59 AM by CUDA JAS »
74 'cuda 360/727
Offline dirttrackdemon
« Reply #7 on: November 17, 2007 - 03:31:36 AM »
I stock car raced a couple of E-Bodies and I found that the center shaft is hollow. The shaft is made to collapse when hit in the front. The shafts are held together by plastic rivits. Those rivits can be sheared off and the shaft will move in and out with no problem. No need to change columns to go from manual to power or vice versa.
Just my .02 cents.
Offline CUDA JAS
  • vroooooom!
« Reply #8 on: November 17, 2007 - 11:37:49 AM »
Just my .02 cents.
I have heard that as well...but I have also heard that the diameter of the shafts (manual vs power are different) and will only fit into there respective  couplers.
Although, I am willing to give it a shot if I can find a power column or just the shaft at the right price.
Jas
74 'cuda 360/727
« Reply #9 on: November 17, 2007 - 02:33:48 PM »
The coupler splines are a different size from manual to power. But the shafts are the same and either coupler works on either shaft. I have a shaft if you  need one just let me know. 15 bucks to you plus shipping.  I am not selling it, I just offered it to you if you cant find what you need.
Offline CUDA JAS
  • vroooooom!
« Reply #10 on: November 18, 2007 - 03:30:31 PM »
Thank you for your generous offer.
I sent you a PM. :thumbsup:
Jas
74 'cuda 360/727
