Was rear swaybar standar on 70 'cuda?
Author Topic: Was rear swaybar standar on 70 'cuda?  (Read 4955 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
« on: January 01, 2007 - 03:05:38 PM »
Was rear swaybar standar on 70 'cuda (BS23) or a option? As my 'cuda don't have one as far as i can see.
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
Alaskan_TA
Re: Was rear swaybar standar on 70 'cuda?
« Reply #1 on: January 01, 2007 - 03:11:23 PM »
It was optional.
« Reply #2 on: January 01, 2007 - 03:13:09 PM »
Have fun drilling into the frame to put it on.  :pullinghair:
Offline widing'cuda
« Reply #3 on: January 02, 2007 - 01:12:12 PM »
Ok, that was what I thought. Any special aftermarket rear sway bar you guys recomend. I have ladder bars on the 'cuda.
Offline 1BADFISH™
« Reply #4 on: January 02, 2007 - 01:33:10 PM »
www.firmfeel.com has the best one IMO....closest to the factory setup.
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
cudahob
« Reply #5 on: January 02, 2007 - 03:55:11 PM »
Mine is stock equipped.  :naughty:
« Reply #6 on: January 02, 2007 - 06:00:44 PM »
if you have ladderbars you alreay ahve a 3" rear sway bar on the car with 32" levers & adding another sway bar will really make no difference , adding a 2" front sway bar would help though
Offline widing'cuda
« Reply #7 on: January 03, 2007 - 10:04:13 AM »
Good to know. I didn't think of the ladderbars like that. But when you metion it it makes sence. I'll look into the front sway bar. Thanks!
« Reply #8 on: January 03, 2007 - 12:47:17 PM »
I have built 2 cars with laddrbars both were amazing I could barely spin a 5" wide Bias ply tire with a 340 4 spd , it hooked HARD on junk tires , the Duster was nuts , 10" tires & 2-3' wheelstands even on the street with street tires , but when pushed in corners only the front would sway , it would pick up the inside rear tire right off the ground & you would hear it chirp as it touched back down coming out of the corner
Offline heminut
« Reply #9 on: January 03, 2007 - 06:45:30 PM »
I've never had any experience with a ladder bar setup, but always heard it was not a good setup to run on the street.
1970 5.7 Hemi Cuda
« Reply #10 on: January 03, 2007 - 08:29:13 PM »
I feel they are the best street system , less finiky than the 4 link & if a rod end fails you have either a capture loop or the leaf spring to keep the diff in place , I use the leafs springs with housing floaters
