Author Topic: Victor heads?  (Read 1218 times)
Offline bb71challenger
Victor heads?
« on: January 02, 2007 - 04:50:26 AM »
Are these out yet? If so how do they compare with Indy EZ heads?  :feedback:
*Brett*
Re: Victor heads?
« Reply #1 on: January 02, 2007 - 11:01:46 AM »
they are out , I am working on a 440 with them right now
 the Victor heads are a more serious head with a true closed chamber & requiring offset intake rockers as the pushrods are moved over so the intake port is virtually straight
 So far the problems encountered have been that the Eddy valley tray doesn`t fit the eddy heads , the Mopar offset rockers that the heads were designed to work with have been discontinued  so you will need to use Indy or Hughes rockers , & the shaft holddown / spacer blocks that Hughes have do not line up the rockers correctly on the head so we are having those custom machined as I type , it looks liek the pushrod holes will need to be opened up to clear the pushrods too , the heads can be ported to Max Wedge size if desired & they  will out flow the Indy 440-1 if you do that according to a friend with a flow bench
 I cannot figure out why eddy always releases their stuff with only 1/2 the engineering done & no support for needed parts to work with their junk
Offline moper
Re: Victor heads?
« Reply #2 on: January 04, 2007 - 02:17:27 PM »
...the RPM heads work with stock stuff...and quite well..lol. Once you get the guide clearances and decent springs on them..lol. :dunno:
Re: Victor heads?
« Reply #3 on: January 04, 2007 - 02:19:49 PM »
& assuming the valves don`t hit the pistons like they did on the one I did with only a .520 lift cam
Offline moper
Re: Victor heads?
« Reply #4 on: January 05, 2007 - 07:06:23 AM »
Now C'mon... Whose fault is that? :bigsmile:  You know never to trust "bolt on" labeling..lol.
Re: Victor heads?
« Reply #5 on: January 05, 2007 - 12:20:19 PM »
we caught it long before we fired it But the valves are not in the same place & hit the edge of the valve reliefs in the piston , instead of lining up with the reliefs
Offline KellysCuda aircard
  • Its good to be blown
Re: Victor heads?
« Reply #6 on: January 06, 2007 - 04:01:44 PM »
Once you got all the bugs worked out, I might be interested in a set of them heads
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Victor heads?
« Reply #7 on: January 06, 2007 - 11:13:52 PM »
I had the same problem with my RPMs.  I was going to use 1.6 rockers on my 360 with the Comp XE268 (.477") cam, but due to the close tolerances of the intake valves and the reliefs, I had to stick with the stock 1.5 rockers.
I also noticed the RPM intake ports required extensive sanding/grinding to matched up with the RPM heads.  Interesting how they make parts that go together, but their ports are not even close to lining up correctly.
Re: Victor heads?
« Reply #8 on: January 07, 2007 - 12:48:03 AM »
well now would be a good time to swap with you engine out & apart , I should have the valve train issues sorted out within the next 2 weeks
Re: Victor heads?
« Reply #9 on: January 07, 2007 - 09:34:17 AM »
I will probly have to run one more season on these heads Neil, wifey is still in shock on how much I spent last year, I would hate to push her over the edge.   :poopoke:. But I think when I do next yearstear down i will be able to afford it.
Re: Victor heads?
« Reply #10 on: January 07, 2007 - 01:12:24 PM »
Sure , gives me time to get soem results on the victors
