Author Topic: fueltank strap bolt  (Read 1149 times)
Offline TreeFrog
    • TreeFrog
fueltank strap bolt
« on: January 02, 2007 - 12:21:14 PM »
I removed my fuel tank and just my luck broke one of the strap bolts.
I can see no way to remove or replace the bolt, short of drilling a hole thru the trunk pan.
anyone deal with this?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Re: fueltank strap bolt
« Reply #1 on: January 02, 2007 - 12:23:54 PM »
the bolt is a J bolt , lift it & twist & it will pop out of the body , easily replaced unlike the newer mopars  :banghead:
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: January 02, 2007 - 12:46:43 PM »
I have one laying around if you need . . . here is a pic of what they look like.
Offline TreeFrog
    • TreeFrog
« Reply #3 on: January 02, 2007 - 12:55:06 PM »
Yes I need one...(although the one I broke is a bit shorter)
...as far as twisting...I have tried everything I can think of and the head is larger than the hole...but will try again...now that I am no longer on vacation...it might work - lol
Offline 4Cruizn
  • HEMI FISH
« Reply #4 on: January 02, 2007 - 01:00:09 PM »
Treefrog . . . it sits in a groove so slide it to the top and there should be room for it to exit the slot.  To remove the strap, you need to twist that to get it out, not the bolt I believe.
I saw one yesterday in my extra bolts, let me look again.   :2thumbs:
Offline TreeFrog
    • TreeFrog
« Reply #5 on: January 02, 2007 - 01:03:24 PM »
the slot that the bolt sits in has a large hole at the top (lift the bolt and it should come out)
Problem the flat head is Much larger than the largest part of the hole....
I truely see no way to get it out short of drilling a hole thru the trunk and dropping a new one in....then just plug it with a small plug
Offline 4Cruizn
  • HEMI FISH
« Reply #6 on: January 02, 2007 - 01:04:50 PM »
They had to get the bolt in there somehow??  I'd try again.   :bigsmile:
« Reply #7 on: January 02, 2007 - 01:08:07 PM »
it will come out , slide it to the top of the slot move it to one side & twist the other side of the head will fit through the hole
Offline TreeFrog
    • TreeFrog
« Reply #8 on: January 02, 2007 - 01:19:43 PM »
I will be trying this evening no doubt!
I want that thing replaced...
then again I need a sending unit(and gasket), a tank, filler grommet, and to clean the filler tube...but it would suck to get the tank and not be able to install it. :working:
Offline TreeFrog
    • TreeFrog
« Reply #9 on: January 04, 2007 - 06:17:09 AM »
OK after three seperate lengthy atemps... the suck dropped out as I was giving up on it comming out the easy  way... FREE, FREE at last!
Offline 4Cruizn
  • HEMI FISH
« Reply #10 on: January 04, 2007 - 08:24:17 AM »
I'll send you the one I have either today or tomorrow!   :ylsuper:
Offline TreeFrog
    • TreeFrog
« Reply #11 on: January 04, 2007 - 08:37:51 AM »
 :worshippy
You R Da Man!
Thanx!
I still have to get the Tank/Sending/Filler Gromet, so there is no major rush.
Maybe I will bolt a boat tank in the trunk - lol
Offline TreeFrog
    • TreeFrog
« Reply #12 on: January 10, 2007 - 11:55:19 AM »
Hey a BIG thumbs-up to 4Cruizn for the help!  :thumbsup:
