Author Topic: Power Booster mounting question  (Read 1024 times)
Offline bnorth
« on: January 03, 2007 - 08:51:57 AM »
Hello to all,
                 I am thinking about replacing the manual brakes on my 70 Challenger with Power.
I have a couple of good 72 and 73 power boosters but they both have 4 studs to mount on to the firewall with.
The problem is the firewall has 2 studs that seem to be pressed in.
If I do decide to mount the power booster on this car it looks like I will need to cut these flush with the firewall and then drill them out.
Anyone have any solutions ?
thanks
Ben
Re: Power Booster mounting question
« Reply #1 on: January 03, 2007 - 12:42:11 PM »
personally I am not a fan of power brakes at all so I would leave them alone
are the studs pressed into the reinforcement plate on the fire wall or possibly into the pedal braket inside the car ? either wya you sould be able to unbolt the piece you need out of the way
Offline bnorth
« Reply #2 on: January 04, 2007 - 08:26:34 AM »
They are pressed into the pedal bracket. I have a couple of brackets but they all have the 2 studs.
I am considering just running manual and keeping it simple at this point. I do have all of the stuff I need to set up for power, linkage etc.
I guess there are brackets out there w/o the studs I just cant find one.
Ben
Offline heminut
« Reply #3 on: January 04, 2007 - 09:08:34 AM »
If they are pressed in you should be able to knock them out with a hammer, just like you would with wheel studs.
1970 5.7 Hemi Cuda
Offline ShelbyDogg
« Reply #4 on: January 12, 2007 - 06:14:02 PM »
I put power and discs on my 70 Chally after the 11"x3" heavy duty drum brakes faded on me after a high speed highway run.  If you have all of the parts, do it and don't turn back. You'll be glad that you did.
« Reply #5 on: January 12, 2007 - 08:30:38 PM »
definatly convert to discs , i just like manual disc
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #6 on: January 13, 2007 - 01:11:51 AM »
