a roller cam can be very expensive to run on a street engine , the Cam lifters & springs will be $1000 , & you need a bronze gear drive for the oil / dist which wil wear out every 2 oil changes , I would go to a strong solid lifter grind & get close to street roller profile & performance with less cost & more reliability
A few cams I use often are the UltraDyne Tf 62 grind , 270 ad duration , 243@.050, 110* CL with .548 lift , using 1.6 rockers this will get you .586 lift , it idle like a stock cam but pulls HARD to 6200 rpm , the other grind is the TF60 278 * ad duration , 251@.050 , 108* CL & .570 lift with 1.5 rockers , .608 with 1.6 rockers , the powerband only rises slightly with this cam with a 2200 - 6500 powerband
the first cam with a 112* cl made 125 more gross HP in a 440+6 engine that appears stock using Cast exhaust manifolds etc [520hp vs 395 stock rating ]
