Author Topic: ignition question  (Read 1562 times)
Offline RAD1229
  • 72 Challenger
ignition question
« on: September 06, 2003 - 12:43:05 PM »
 >:(    When I turn the ignition through I get no response!  Good battery, I know new ignition switch, that has worked for months!  When I bridge from post to post on the solenoid I can get it to turn over!  Do you all think that the solenoid id the problem??  Has anyone had similar trouble??
Appreciate any help
RAD
1972 Challenger
Re:ignition question
« Reply #1 on: September 06, 2003 - 12:59:51 PM »
sounds like the starter solinoid is the problem
Offline RAD1229
  • 72 Challenger
« Reply #2 on: September 06, 2003 - 01:36:49 PM »
 :-\  I'll let you know how it goes, installing a new one shortly!
Thanks Chryco!
1972 Challenger
« Reply #3 on: September 06, 2003 - 05:42:24 PM »
 ??? Wouldn't a bad starter relay cause the same symptoms?
« Reply #4 on: September 07, 2003 - 06:54:31 AM »
not if it starts with the relay shorted
seems I had the terminology backwards
« Last Edit: June 22, 2005 - 12:16:07 AM by Chryco Psycho »
Offline johnny-d
  • Death is certain, Life is not - think about it
Re: ignition question
« Reply #5 on: June 21, 2005 - 04:41:35 AM »
This problem sound like the one I am now having - turn the key & nothing happens but can turn the engine over under the hood.
RAD - what'd it turn out to be?
« Reply #6 on: June 22, 2005 - 12:15:13 AM »
Umm should be a bad starter relay on the inner fender
