Author Topic: 340 heads on a 318  (Read 1148 times)
Offline phf
  • project: PHF 'Cuda
340 heads on a 318
« on: January 08, 2007 - 09:41:57 PM »
would putting 340 heads on a 318 improve power outputs over putting a set of 360 heads cut .060in?
thnx  :ylsuper: stan
I'm jus here to feed my fish rice
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: 340 heads on a 318
« Reply #1 on: January 09, 2007 - 02:00:26 AM »
humm...which 340 heads?, are they ported?, what is the compression of the 318?, cam?, etc.?
Offline GoodysGotaCuda
« Reply #2 on: January 09, 2007 - 07:17:48 AM »
I agree. For the most part...340 heads arent much different than 360. (i wanna say they are the same, but i rather not sound that stupid if not lol. Xs = 340 Js= 360...but really arent different? ??? :biggrin:)
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline heminut
« Reply #3 on: January 09, 2007 - 11:17:54 AM »
The only real difference between the 340 heads and the 360 heads is that the 340 heads have a slightly larger intake valve.
1970 5.7 Hemi Cuda
« Reply #4 on: January 09, 2007 - 11:41:18 AM »
Were the 340 heads all 2.02? and the 360s were 2.02 or 1.88?
1976 Dodge Warlock
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #5 on: January 09, 2007 - 12:41:46 PM »
 :popcorn:  I'm curious about this too.   :clueless:
I know that some 340s had the smaller 1.88 valve, maybe starting '72 with the low compression engine, but these may be 360 heads, I dunno...  :dunno:
Offline tactransman
« Reply #6 on: January 09, 2007 - 01:59:18 PM »
'71 and earlier had the 2.02 . I put 1.88 360 heads on a 318 in a '77 PU truck and it screamed, especially on the highway. I would think 2.02 would be too much for a 318, probably shroud the intake valves by the  block bore size.
« Last Edit: January 09, 2007 - 02:01:31 PM by tactransman »
Terry-tactransman
Union, Mo.
« Reply #7 on: January 09, 2007 - 08:51:57 PM »
I would be looking at the swirl 308 360 heads with the smaller valve for a 318
« Reply #8 on: January 09, 2007 - 09:12:09 PM »
my boat anchor mill has 2.02s on it, milled. probably shrouded decently i'd assume.  :eek4: runs fine though.  :biggrin:
1976 Dodge Warlock
Offline heminut
« Reply #9 on: January 10, 2007 - 09:29:53 AM »
:iagree: As far as I know, all the 360's had 1.88 intakes. After 71 I believe they used the same heads on both 360 and 340 engines.
1970 5.7 Hemi Cuda
Offline phf
« Reply #10 on: January 12, 2007 - 11:47:15 PM »
so is there any difference in flow-ability between a 1.88 360 head,casting 308 and the 1.88 340 head, casting 915?
« Reply #11 on: January 13, 2007 - 12:33:31 AM »
yes the 308 is better
Offline phf
« Reply #12 on: January 13, 2007 - 09:26:30 AM »
ok, thank you
