Author Topic: 318 to 340  (Read 1007 times)
Offline TreeFrog
    • TreeFrog
318 to 340
« on: January 09, 2007 - 06:51:21 AM »
I have an 82 318 I am considering rebuilding - if I wanted to convert it to the equivalent of a 340 .... a badass lil 318 basicly what would you suggest?
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline GoodysGotaCuda
Re: 318 to 340
« Reply #1 on: January 09, 2007 - 07:15:13 AM »
equivalent to a stock 340? what are you lookng to do?
heres my specs
http://www.goodysgotacuda.com/CudaMods.html
284rwhp SAE  :clueless:
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline TreeFrog
    • TreeFrog
Re: 318 to 340
« Reply #2 on: January 09, 2007 - 08:08:34 AM »
OK, kinda expected that...lol
if I were to run my 318 against your 340 I would want them on a fair / even playing field.
I do not know enough about the tech specs of each engine to compair.
boring, stroke, heads, etc.
put 340/360 heads on, after market heads, cam etc.
I will drive this on the road, but if I want to run  someone I want to know I have a good chance at beating them...
Re: 318 to 340
« Reply #3 on: January 09, 2007 - 08:58:32 AM »
Well i know you said 340/360 heads, aftermarket heads...you mean intake? whats the budget on this sucker? if you plan on building one, build a little monster like this. bascially what i have but with more cam (fairly) and different pistons to run that cam
http://goodysgotacuda.com/318build.html
here is a video of a modded 340 vs my modded 318. he ran drag radials, i ran radials and my old pos converter. that night i was ran a 14.3, he ran a 14.60. he has since got his e/t down to 14.3 now, i'm at 14.0 at vegas running dry (gas) at the top end, fwiw. i should be able to do 13s no problem now that im in florida.  :cooldancing:
« Last Edit: January 09, 2007 - 09:00:13 AM by GoodysGotACUDA »
1976 Dodge Warlock
Offline TreeFrog
    • TreeFrog
Re: 318 to 340
« Reply #4 on: January 09, 2007 - 09:03:47 AM »
There is no true Budget at this point.  I am doing a Fesability study for lack of better terms.  I have several engines to choose from. 318 and 383 in need of rebuilding, a 360 that will cost me a little but runs, or whatever a guy I know has on hand (hoping for a 340 and if not a 440)
I like the idea of staying small block...resonable to drive and still fun.
no I was speaking of heads.  I have an alum 4bbl intake, so that is covered ...Edlb Tourker I think...
Offline moper
Re: 318 to 340
« Reply #5 on: January 09, 2007 - 10:25:57 AM »
Use the 360 if posssible. The longest stroke makes the most power where you need it. You can build a nice 318 (400hp+) for about $4K that will embarass a lot of cheaper build 340s.
Re: 318 to 340
« Reply #6 on: January 09, 2007 - 10:47:48 AM »
use a 360 , they are cheap to get & will make more torque , & torque moves the car
Offline TreeFrog
    • TreeFrog
Re: 318 to 340
« Reply #7 on: January 09, 2007 - 10:59:59 AM »
4K in parts or paying someone to build it? (may sound dumb)
Offline TreeFrog
    • TreeFrog
Re: 318 to 340
« Reply #8 on: January 09, 2007 - 11:06:53 AM »
True .. could always tell them its a 318 ...lol
My favoright is a local guy using the 340 name bage...running a 440...not like a big block looks like a small block...
