Author Topic: 72 -74 Challenger grille options  (Read 2581 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
Re: 72 -74 Challenger grille options
« Reply #15 on: January 11, 2007 - 09:31:23 PM »
My header was damaged slightly. It's really SMC, or a type of polyester resin, similar to fiberglass.
Fiberglass is easy to repair, the only troubel is allighnment if the panel is split.
I don't have any problem " Ruining " a header panel, only beace you can find them pretty easily, as  everyone is focused on the 70 & 71. Personally, your idea of incorporating the "new" Challenger grille and the old header panel is a very worthy idea. I had discussed this with my friends at work previously. They too, liked the idea.
I will attempt to see what CAN work.
dan
Offline TreeFrog
    • TreeFrog
« Reply #16 on: January 12, 2007 - 06:01:18 AM »
I wanted to replace my header pannel but shipping was always a killer when you added it to the cost.
I have a small piece that was pulled out of the bottom edge (where the bumper filler screws into the end), and a fracture between two buckets that goes all the way down.
I have a guy that I feel can do a good job, and will try to have mine repaired...would rather have just replaced it...but...
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline DMZ73
« Reply #17 on: January 12, 2007 - 06:52:43 PM »
Brace it first, then just carve out a valley at the crack site, and reinforce with F/G. Sand and apply filler done. The kids go home happy. :thumbsup:
On another note, I got a hold of a Dodge Charger grille today, and I will measure/find the difference between the two and post my results.
Dan
Then there's this new one.....
