Author Topic: heaterbox resto  (Read 1162 times)
Offline roy282
heaterbox resto
« on: January 11, 2007 - 08:08:26 AM »
I'm in the process of restoring the heaterbox and after giving it a bath with soap and water I have some white faded spots would like to know what type of paint I should use or solvents to bring it back to the original look.Also would appreciate any info on the gaskets used on the  inner flaps?THANKS FOR MOPAR KNOWLEDGE ROB and did the blower moter come factory black?
1974 barracuda 360 gone
1968 charger 318 gone
1970 barracuda gran coupe 383 4spd Gator in the garage
Offline Lunchbox
Re: heaterbox resto
« Reply #1 on: January 11, 2007 - 09:47:37 AM »
This site has some a pretty decent article about restoring your heater box and how they painted to look original.
http://www.moparmusclemagazine.com/techarticles/34500_mopar_ac_system_restore_ii/
Also check this site out has some good pics of heater boxes ripped down and restored.
http://www.smsmopar.com/public/products.asp
Hope this helps
Lunch
Offline PlumCrazy
Re: heaterbox resto
« Reply #2 on: January 11, 2007 - 09:54:35 AM »
Gaskets
http://www.DetroitMuscleTechnologies.com
Motors were clear zinc.
Offline DAYLEY/CHALLENGER
Re: heaterbox resto
« Reply #3 on: January 11, 2007 - 10:50:55 AM »
 :wave:Not that I did everything right... but I think it turned out ok..
http://big-dog.us/challenger/images/Albums/24/index.html
Dave or David
Re: heaterbox resto
« Reply #4 on: January 11, 2007 - 04:54:59 PM »
Roy, The motor colors must vary as most pics I see are silver while my '73's OE is black.
 An idea to bring your boxes finish back try satin clear urethane.
« Last Edit: January 11, 2007 - 05:50:28 PM by bullitt99 »
Offline RUSTY Cuda
  • One big step foward!
Re: heaterbox resto
« Reply #5 on: January 11, 2007 - 05:30:50 PM »
There's a guy on ebay selling the foam kits 35 for heater includes the 2 fresh air vent gaskets too, 50 somethin for an a/c box, if you need a link shout out, I'll dig for it! Rich.
Offline FY1Cuda
Re: heaterbox resto
« Reply #6 on: January 11, 2007 - 11:55:08 PM »
We had some urethane foam (from a surplus/upholstery supply store) that I had used under some vinyl for a door panel (on a Morris Minor). We just duplicated the shape of the door gaskets and stuck it on with contact cement.  Works fine and cost almost nothing.
Offline cwestra
Re: heaterbox resto
« Reply #7 on: February 22, 2009 - 12:23:51 PM »
I am in the process of restoring my non A/C '70 heater box and have purchased a rebuild kit for it.  The original foam is dust but I noticed on one of the interior doors under where the foam was is a yellowish tinted celohpane sheet glued to both sides, overhanging the door itself.  I believe the overhang is to assure a tight fit.  My replacement foams are slightly bigger than the door as well.  Should I remove the original celophane sheets or just glue the new foams to it?
Corey - in Northern Indiana
