Author Topic: Air Lock ???  (Read 875 times)
Offline Madmax440
Air Lock ???
« on: January 11, 2007 - 08:38:47 PM »
Everytime that I take my gas cap off to put gas in the car there is a sudden air release and continues to gush out for a few seconds - Do I have a problem here ???
71challengher
Re: Air Lock ???
« Reply #1 on: January 11, 2007 - 08:51:47 PM »
sounds like the tank is not vented
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: Air Lock ???
« Reply #2 on: January 12, 2007 - 12:00:51 AM »
It may depend on the cap.
If you have a vented cap, then it will let air in but not out.  So if the temp changes a few degrees, the presure will rise and will be released when the cap is removed.  Mine does this all of the time and I have never had a problem.  I also do not run a return line either.
I am not sure about the non-vented cap.
Re: Air Lock ???
« Reply #3 on: January 12, 2007 - 03:16:47 PM »
Is air gushing in, or out?? If air is gushing in, then that's bad. My vent tube went to heaven on my car, and my fuel pressure would drop like a rock after a few minutes on the Hiway. Simply because the fuel pump can't suck the gas forward, if air isn't entering the tank.  :swear: Sputter, sputter.  :swear: In  70 the caps were not vented, but your 71 should be, if it still has the stock cap on it.
Offline Madmax440
Re: Air Lock ???
« Reply #4 on: January 14, 2007 - 06:41:04 AM »
Thanks - Sounds like I have to get me one of them thar vented caps.
