Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Power Steering Box R/R
« previous
next »
Print
Pages: [
1
Author
Topic: Power Steering Box R/R (Read 1319 times)
TrakHor
Jr. Member
on:
January 13, 2007 - 04:21:25 PM »
Is it possibe to replace a power steering gear with the motor in the car with factory manifolds?
Thanks
Jason
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Power Steering Box R/R
Reply #1 on:
January 13, 2007 - 05:07:59 PM »
no Factory manifolds will not steer the car
OK seriously you will probably have to remove the manifold but it should be possible , I have done it on a Hemi car
Logged
DAYLEY/CHALLENGER
Resident
Still My Inspiration..1971, Rockingham, Nc
Reply #2 on:
January 13, 2007 - 05:24:25 PM »
Good One.........
Logged
Dave or David
TrakHor
Jr. Member
Reply #3 on:
January 13, 2007 - 05:46:57 PM »
I sorta didn't complete that sentence did I? It' seams you've gathered I ment while on the car. Thanks
Logged
Mopar73340
Sr. Member
Reply #4 on:
January 14, 2007 - 09:23:27 AM »
Just replaced mine, just barely had room to get it out between the head and the shock tower with the mainifold off so to answer your question no it won't come out without removing the manifold.
Logged
jvike
Full Member
Pro-Touring Cuda
Reply #5 on:
January 18, 2007 - 06:03:18 AM »
I'll have to replace mine too.. but I got TTI headers.. will those clear? 340ci
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
January 18, 2007 - 12:01:18 PM »
I doubt you will get it out without as least moving the header around
Logged
Mopar73340
Sr. Member
Reply #7 on:
January 18, 2007 - 02:06:30 PM »
Quote from: Chryco Psycho on January 18, 2007 - 12:01:18 PM
Logged
ROMI
Full Member
71 Challenger R/T 340 4 speed, Lapeer Michigan
Reply #8 on:
January 18, 2007 - 04:40:06 PM »
I had to unbolt the headers (didn't have to take out) but also had to remove the battery and battery tray. If you remove the pitman arm first you probably won't have to remove the battery tray but that's a bit harder.
Logged
jvike
Full Member
Pro-Touring Cuda
Reply #9 on:
January 22, 2007 - 02:14:13 PM »
I've got the battery in the trunk.
To bad I've got to loosen the headers, hate those bolts that goes into the waterchannel!
Logged
DAYLEY/CHALLENGER
Resident
Reply #10 on:
January 26, 2007 - 05:39:18 PM »
As close as my headers are to the steering box I think it would be a problem. I had to remove the header to install a new starter. The header is also dimpled over the steering box and has only 1/4" to 3/8" clearance.
Logged
Dave or David
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
