Cam lobe went bad. do I rebuild or not?
Author Topic: Cam lobe went bad. do I rebuild or not?  (Read 2282 times)
« on: January 14, 2007 - 10:31:53 AM »
So do I do a complete teardown or throw in a new cam and let the oil filter pick up any old particles? Money is not falling off trees to me. The engine has 4 hours ran on it. (see avatar) What procedure should I do. Because when it's in the engine bay, it ain't comin out. I was thinking of buying a cam so I need to know before I do buy one. thanks.
Re: Cam lobe went bad. do I rebuild or not?
« Reply #1 on: January 14, 2007 - 10:51:16 AM »
I woudl flush out the engine possibly replace the oil pump , which cam went bad ?
« Reply #2 on: January 14, 2007 - 11:55:29 AM »
The guy I bought it from had a Mopar performance purple camshaft in it. it was a Hyd. He broke in the engine and then it had problems running. Thus, the cam was the problem. He said it ran for about 4 hours total on it then he shut it down and it hasn't been ran since. The engine has been kept in dry storage with our low humidity conditions for about 4 years. I recall that there was some superficial rust on the crank and rods when I inspected it when I bought it. I was wondering about that too. What do I flush it out with? And how? Engine degreaser spray can? Thanks CP.  :thumbsup:
« Reply #3 on: January 14, 2007 - 12:19:01 PM »
here is a pic of the bad lobe. was pretty rounded off.
« Reply #4 on: January 14, 2007 - 03:04:04 PM »
basically I would pull the pan & clean it out , most of the metal will be there or in the filter , only the oil pump is not protected by the filter , clean out the oil pump now  including the bypass valve  &  change oil a few times in the first 500 miles to wash most of the metal out into the filter & replace the oil pump after 500 miles or so , keep an eye on the oil pressure with the old oil pump
« Reply #5 on: January 14, 2007 - 03:19:43 PM »
Thanks CP. I want to talk with you more later on the phone when I'm ready about camshafts.
« Reply #6 on: January 14, 2007 - 03:26:36 PM »
no prob , I can call you for free so let me know
Offline tactransman
« Reply #7 on: January 14, 2007 - 03:36:58 PM »
:iagree: That's exactly what I did on a 440 that had a cam lobe go bad, it was fine afterwards for many hard runs.
Terry-tactransman
Union, Mo.
Offline jeryst
« Reply #8 on: January 14, 2007 - 04:18:26 PM »
In addition, go to an auto parts store and see if you can find a magnetic drain plug. It will hold any tiny bits and keep them from recirculating between oil changes. I had to do that once, and you wouldn't believe how much it collected. Make sure you get one with a good strong magnet, as some of them are cheap, and not very powerful.
« Reply #9 on: January 14, 2007 - 05:21:59 PM »
Thanks, good idea.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #10 on: January 14, 2007 - 08:06:32 PM »
I am running one of those also, it works well.
Offline moper
« Reply #11 on: January 16, 2007 - 10:07:26 AM »
If you're talking a Hemi, I would tear it down and clean it all out. 4 hours means it went everywhere. Oil is splashed on cylinder walls and the iron will score pistons and trash ring seal, thrust bearing surfaces get doused with it. Oil galleries (especially 90° drilled passages) get deposits of it. What goes thru the pump gets into everything. Never mind iron particles that are smaller than the oil filter media. Mere prescence of metal means it should be cleaned out. Especially if it's not in the car yet. Plus...Why did the cam go bad? Do you actually know, or was a new cam just installed? They dont go bad for no reason.
« Reply #12 on: January 16, 2007 - 06:09:59 PM »
Some good points heard. the previous owner said he had a rocker adjustment overtightened.
Offline 67Vette427
  • My other car is not a Rambler
« Reply #13 on: January 16, 2007 - 10:32:16 PM »
I've had a couple cams not break in right and the lobes/lifters got messed up. Because I was there and knew it didn't run for too long, I cleaned the pan, checked the pump and the bearings by pulling some caps. All was okay. Since it sounds like you got this motor from somebody else who had this happen, I think I would go through it, especially if you already have it out. Who knows what else he did or didn't too. Its an expensive motor compared to what it would cost to have it checked. Minimum, I'd check the bearings and do everything all the others mentioned.
« Last Edit: January 17, 2007 - 12:11:14 AM by 67Vette427 »
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
« Reply #14 on: January 16, 2007 - 10:48:33 PM »
I think then I will concur with a teardown then. It's an original 71 block and I have to do it right. No sense in taking a risk. it's never been bored out either.
