I agree with moper with the split duration with street- strip cars. And psycos Engles cams is a good co. They used too make hughes cams. Some get into trouble with too fast a lobe ramp. If your lifter bores were not bored in the correct position, the lifters edges grind into the lobe. I used too talk too harold (ultradyne) alot, been 4 years tomorrow since last time,and his edge of tappet got no closer than .017 which gave an extra .015 using a ford profile on a chrysler 904 lifter, and an extra .048 using a chevy design.
I always wanted to use the 528 mp cam back in 75, but still have 471- 474 mp 68 overlap. Idiots said 528 was to big. I still like to try it if go back to manifolds, but hear they roud out alot. Magazines and comp cams tried too beat the 528, but couldnt. I can see why talking too comp cams last week at the clearwater, fl sema type of show. He didnt want too talk about thier mm lobes, just that they will wipe out and insisted that i go hyd roller. I told him im considering going too thier extreme energy solid roller 570- 576 242- 248 280- 286, but at 112, he kept saying go hyd at those rpm. But the hyd roller lifters weigh a ton!
One other Harold used too say, at .200 lift, the 528 is 152degrees, said his ford lobeswere at least 6 more at .200 with similar lift. very easy too beat.
Now that rotella is sm rated, i just might go with a roller, and like mopers 6 pack restrictive as heck, i just mighr sell the 6 pack if someone wont sell me 2 end floats (thier shorter?) and call the supercharger store, but have too decide before buying the cam. I would then go 114 lsa with the roller and forget going too a 505.
