Author Topic: 8 3/4 oil drain?  (Read 1536 times)
Offline AMXguy
8 3/4 oil drain?
« on: January 14, 2007 - 05:41:08 PM »
Ok I don't want to sound like an idiot but how do you drain an 8 3/4 rear end? the TSM drawing shows a plug but mine is nice and clean and I can't find one. I tried a suction gun but I can't get the hose to go down in the hole. you don't crack it open do you? that looks like a good way to start a leak.
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: 8 3/4 oil drain?
« Reply #1 on: January 14, 2007 - 05:52:23 PM »
I've always put a pan underneath and cracked them open. Then I replace the seal, because of leaks and I am usually replacing the 3rd member (having a hard time deciding what gears I like, sso I have been swapping pumpkins a lot lately).
1996 Dodge Viper GTS Coupe
« Reply #2 on: January 14, 2007 - 06:36:22 PM »
it has no drian plug in the housing
Offline duodec
« Reply #3 on: January 16, 2007 - 09:37:14 PM »
If you are not pulling the pumpkin you need a good quality suction gun, but you will never get all of it out.  A cheap gun won't work too well; the lube is usually too heavy.  The one time I did mine I used a heat gun on low to warm up the center section for 30 minutes, then most of the lube came out fairly easily.  When I have to do it again I'll pull the pumpkin.
Offline 1970hemicuda
« Reply #4 on: January 27, 2007 - 01:09:13 PM »
The best way is to crack them open and then replace the seal.
« Reply #5 on: January 27, 2007 - 04:52:31 PM »
I undo all of the 10 bolts holding the housing place & leave the to bolt in place but loose & use a Jack to lift the nose of the carrier to split the seal
bbscamp
« Reply #6 on: January 30, 2007 - 08:26:22 PM »
I put a drain plug in the housing on my last one.  I'll do it again to this next one.  Just drill a hole at the bottom (opp. side of the ring gear)...and weld a nut to the inside of the housing (or outside if you prefer).
