Author Topic: what happened to my posi  (Read 747 times)
Offline 73 challenger 440
« on: January 14, 2007 - 09:27:05 PM »
it's been a while since I posted, I hope this is in the right part of the forum.. but last summer I swapped over from 235's to some 295's on the rear. for some reason my posi rearend doesn't always work.. I checked the tire pressure to be sure they are the same..  just the passenger side will spin...
Offline GoodysGotaCuda
Re: what happened to my posi
« Reply #1 on: January 14, 2007 - 09:28:06 PM »
is it old? just could be worn out.  :clueless:
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: January 15, 2007 - 12:17:03 AM »
if it is ia clutch type it can be rebuilt , if it is the later cone type you need a new one
« Reply #3 on: January 15, 2007 - 12:57:39 AM »
is there numbers i could look for to see what kind it is?? if it's a clutch type could it be just in need of some fluid change?? I really dont believe it's more than a a several years old. the trans, rearend and engine were done close together. from what I was told... I haven't checked for any leaks...
« Reply #4 on: January 15, 2007 - 01:19:15 AM »
you would have to pull the carrier to tell
Offline TreeFrog
    • TreeFrog
« Reply #5 on: January 16, 2007 - 06:56:52 AM »
uhhhho you done gone and broke it!
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
