Author Topic: Heat Shield  (Read 3338 times)
Offline TreeFrog
    • TreeFrog
Heat Shield
« on: January 16, 2007 - 07:12:40 AM »
my car has a heat shield under the trunk...exaughst pipe...
but only on the pass side...
A friend told me it was odd they had taken one off but not the other...
I am not sure if the car had but one...where can I find a drivers side...
used is fine, but while the fuel tank is out I would love to bolt one on.
« Last Edit: January 16, 2007 - 07:20:22 AM by TreeFrog »
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline dougs bs23
Re: HEat Shield
« Reply #1 on: January 16, 2007 - 07:19:31 AM »
originally a single exhaust car??????????? I believe i've seen some repops maybe try autobody specialt's or year one,,, used maybe herbs parts. mine was a single and i picked one up on epay fairly inexpensive
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: HEat Shield
« Reply #2 on: January 16, 2007 - 09:58:54 AM »
My Challenger was a single exhaust with only one shield.
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Heat Shield
« Reply #3 on: January 16, 2007 - 10:27:19 AM »
What year and what engine did the car have originally?  How about the rear valence?  Cut outs?  :clueless:
Offline TreeFrog
    • TreeFrog
Re: Heat Shield
« Reply #4 on: January 16, 2007 - 11:42:13 AM »
best I can tell, it was a 318 single with no cutouts.
currently its a 340 dual with homemade cutouts
I would like to add the shield, but the cost is a bit much for a daily driver that I am fighting to get On the road.
Offline Jacksboys
Re: Heat Shield
« Reply #5 on: January 16, 2007 - 11:48:46 AM »
Are you trying to make your car correct for the year or are you just worried about the heat on the paint?
Offline TreeFrog
    • TreeFrog
Re: Heat Shield
« Reply #6 on: January 16, 2007 - 11:56:42 AM »
just an item that I can easily install while the fuel tank is out.  I do not NEED the part, it did not come on This car. But I though I would look around this morning and see if there was one just laying around...all I have found was new and priced higher that I really care to spend ...
I would rather it be a correct part had this car come with it, even though I am sure it did not. Besides a little extra protection does not hurt my feelings..the car has been dualed this lond without a problem...
Offline Jacksboys
Re: Heat Shield
« Reply #7 on: January 16, 2007 - 12:05:55 PM »
the car has been dualed this long without a problem...
oh ok, I was going to say the same about mine.
Good luck on your search.
Offline TreeFrog
    • TreeFrog
Re: Heat Shield
« Reply #8 on: January 16, 2007 - 12:14:35 PM »
Thax...I was just hoping someone might have one laying about or was removing them to tub the car etc....
Offline moparnocar
Re: Heat Shield
« Reply #9 on: January 16, 2007 - 06:43:52 PM »
I should have one... contact me.. mopar_maniac68 at yahoo.com
Offline DAYLEY/CHALLENGER
Re: Heat Shield
« Reply #10 on: January 16, 2007 - 08:40:22 PM »
Needless to say that the left and right are different...
Dave or David
Offline TreeFrog
    • TreeFrog
Re: Heat Shield
« Reply #11 on: January 17, 2007 - 09:08:49 AM »
Nice looking ... Assuming they are new...or did you clean them...
Re: Heat Shield
« Reply #12 on: January 17, 2007 - 09:57:17 AM »
Cleaned 37 years old!!
Dave or David
Offline TreeFrog
    • TreeFrog
Re: Heat Shield
« Reply #13 on: January 17, 2007 - 10:58:52 AM »
they look nice!
Offline ted
  • 74 cuda, 70 challenger r/t
Re: Heat Shield
« Reply #14 on: January 17, 2007 - 11:45:30 AM »
unless the mufflers are in the stock location, shield isnt needed
