Author Topic: 1999 Ram Truck  (Read 1158 times)
Offline TreeFrog
    • TreeFrog
1999 Ram Truck
« on: January 16, 2007 - 01:40:07 PM »
Dad has a 1999 Dodge Ram 1500.
When you start driving it does not want to upshift, even backing off of the gas does not help.
any suggestions
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline tactransman
Re: 1999 Ram Truck
« Reply #1 on: January 16, 2007 - 04:39:37 PM »
Could be a lot of things,governor pressure solenoid,governor pressure sensor,output sensor. You need to have a "scan tool" hooked up to it and check for codes and readings. Can you give any more information? (did it do this all of a sudden ,mileage, engine etc.)
Terry-tactransman
Union, Mo.
Re: 1999 Ram Truck
« Reply #2 on: January 16, 2007 - 05:40:16 PM »
 I adopted a 98 Dakota work truck w/130K miles on it that may have never had a service performed on it that did not want to catch third but two fluid changes later she worked like new. NOT directly related but we have had several 90's+ Chrysler FWD products & they are very sensitive to fluid change intervals as well as fluid type. One was a 93 Caravan that we had the fluid changed (Express Lube) & the shifting got worse, took it to the dealership & they put the correct fluid in & problems went away. Started taking all changes to the dealer & sometimes there is a software upgrade to be flashed to the computer.
Offline tactransman
Re: 1999 Ram Truck
« Reply #3 on: January 17, 2007 - 10:41:11 AM »
Any updates TF ? ???
Terry-tactransman
Union, Mo.
Offline TreeFrog
    • TreeFrog
Re: 1999 Ram Truck
« Reply #4 on: January 17, 2007 - 12:16:17 PM »
Was waiting on Dad to answer my question....
The Trani shifts fine until it tries to shift from 2nd to 3rd.
It is as if it goes into outerspace at times...
I think it gets hung up between gears and he will have to let off the gas and go thru the shifting isse again.
It was recommended that it might be an Electronic/electrical issue...
I know the 93 Ram I had, had Elec over-drive, and I can not speak enough as to the piece of crap it was...but
Offline TreeFrog
    • TreeFrog
Re: 1999 Ram Truck
« Reply #5 on: January 17, 2007 - 12:56:02 PM »
Just got it ... its a 46-RE Trani.
Offline tactransman
Re: 1999 Ram Truck
« Reply #6 on: January 17, 2007 - 01:57:16 PM »
If it only has the problem from 2nd to 3rd it is the lip seals in the direct (third gear) drum are shrunk up. Very common with the original from the factory internal seals. Only way to fix it right is to overhaul it. :grinyes:  The replacement seals in the overhaul kit will not shrink up. :jumping:
My '99 has 85,000 miles on it , I am waiting for it to develop the same problem........it will some day. :eek7:
Terry-tactransman
Union, Mo.
