Shift Quality of The Keisler Manuals?
Author Topic: Shift Quality of The Keisler Manuals?  (Read 12299 times)
Offline Robb
Re: Shift Quality of The Keisler Manuals?
« Reply #15 on: January 22, 2007 - 11:48:40 AM »
I have the TKO 600 with the .64 5th gear.   I have 25 inch tires and 3.55 gears.
currently with that combo, 1st gear is way too short, and the overdrive gear is a bit of a jump
If I was going to do it all over again, Id probably get some 3.23s or little bit higher, and then get the .84 (?close anyway) 5th gear, where the gear ratios are a little closer together.
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
sleepychallenger
« Reply #16 on: January 22, 2007 - 01:04:18 PM »
i thought that the 1-4 gear ratio was same as factory 4 spd?
Offline Robb
« Reply #17 on: January 22, 2007 - 03:54:25 PM »
check out the website and the comparison calculator
600TREMEC Gear Set: 1st=2.87:1; 5th=0.64:1
A833 Gear Set:          1st=2.65:1; 4th=1:1
46RE Auto. Gear Set:  1st=2.45; OD=0.69:1
NV3500 Gear Set:       1st=3.49; 5th=0.73:1
Offline Carlwalski
« Reply #18 on: January 22, 2007 - 05:42:04 PM »
Thanks, that's the same as I'm looking at. I have 28" tires and 3.23s. How short is short?
If you go .84 TK0-600 won't the gears been even shorter or closer ratio?
 :dunno:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline Carlwalski
« Reply #19 on: January 22, 2007 - 05:43:00 PM »
Hey Carl, Cool car! Are they AWD?
Thanks Dave.  :2thumbs:
Nope, RWD. All the Ford V8s and Holden V8s down under are RWD.  :ylsuper:
Offline 1BADFISH™
« Reply #20 on: January 22, 2007 - 06:28:35 PM »
 :burnout:  Lucky dog...400+ hp rwd.   :wow:
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Offline Carlwalski
« Reply #21 on: January 22, 2007 - 06:45:53 PM »
...Manual.  :ylsuper:
Offline Carlwalski
« Reply #22 on: January 23, 2007 - 02:01:09 AM »
I just checked their website and the 1st to 4th ratios remain the same on both the TKO-600's. I used their "Speed Analyzers" chart page and the gear ratios remained the same, only the final gear ratio changes from 0.64 to 0.82. I'm not sure why they would option that, wouldn't everyone opt for the 36% less rpm 0.64 instead of the 18% less rpm 0.82 TK0-600?
http://www.keislerauto.com/tools/mopar_analyzer_5sp.html
Offline Pistol Gripper
« Reply #23 on: January 23, 2007 - 05:32:33 AM »
Gear ratio for the A-833OD is:
75-79 overdrive A and F bodies 75-87 overdrive trucks and vans.   3.09   1.67   1.00   0.73
P.G.
O ne
B ig
A $$
M istake
A merica
Offline Robb
« Reply #24 on: January 23, 2007 - 12:32:14 PM »
easy,
on the analyzer....  on the .64 OD
check the cruising RPM in that OD gear against your tires and rear-gears.  Does it match your cams performance profile and your engines peak efficiency ?
in your situation, at 2200 cruising rpm, your doing ~90mph.   My guess is, unless your roads are like the autobahn, youll never get max use of that OD gear.
Offline Carlwalski
« Reply #25 on: January 23, 2007 - 02:18:01 PM »
I guess, but with lower 65-70mph everyday cruising speeds why would you opt for higher rpms? The 1st to 4th ratios remain the same in both transmissions. I'd rather cruise with lower rpms, not sure about anyone else?   :)
0.82 @ 2,300 is barely at cruising speed - 73mph That's not the greatest rpms. With the 0.64 TKO I can do the same speed with 500rpm (1,800rpms) less wear & tear on the engine while still maintaining the low down grunt, for me, it's a given. That way if I wanted I could still throw a 4:10 in the rear and cruise 2,000rpm @ 63mph.
Thanks Keith.  :2thumbs:
Offline Robb
« Reply #26 on: January 23, 2007 - 03:01:10 PM »
again,
powerband of the motor at the given RPM.         Why not cruise at 800 rpm ?
a 4.10 gear in the rear, you could almost ignore first gear and just go right to second.
If I had to do it over again, I'd do it differently.    good luck
Offline Carlwalski
« Reply #27 on: January 23, 2007 - 09:02:53 PM »
Thanks.
To me, 5th is OD, nothing else.....I would never worry about my rpms/peak performance in that gear as it's not in my nature. I just want my 4 gears with the OD cruise, 5th is highway, nothing else, so performance isn't a factor. Yupe, I know 4.10s would behead the tires but I was just saying those are the options I could go with if I liked. My TS50 is a 5-Speed, I race around in the first 4 gears then hit 5th and relax.  I can see what you're saying though, the 0.64 5th is a slow poky feeling gear while the 0.82 obviously gets better throttle response...I'm not 100% set on it yet but I'm 8/10 for the 0.64 at present.
Offline Carlwalski
« Reply #28 on: January 24, 2007 - 12:17:31 AM »
Whats the difference between the TKO-500 and the TKO-600? Is the 500 a 2005 trans and the 600 the new model?
Or is it strictly a hp thing? TKO-500 rated at 550hp and the TK0-600 rated at 650hp?
 :clueless:
sleepychallenger
« Reply #29 on: January 24, 2007 - 12:58:47 AM »
i think that it is just a hp thing
